Question about Zenith Z50PX2D 50 in. Plasma HDTV
SOURCE: programming
push the tv button then hold down the code search button till the light becomes solid. point the remote at your tv while it is turned on and push the channel up or down til the cannel changes. once it does push the mute key to save. so u know this works like that on all device and if you pass up the right on from pushing the button too fast you can just push the opposit direction rather than waiting for full circle. also be aware that there are multiple codes for some devices and some work better than others.
Posted on Aug 26, 2008
SOURCE: programming remote
The BNZ110 is designed to be for Zenith by default. If it gets changed and won't work, then take the following steps.
1. Remove the batteries.
2. Hold the power button down for 10 seconds.
3. Reinstall the batteries.
This works for many Zenith TV's.
Here are the codes for Zenith if that does not work.
713 502 606 409 710 701 507 714 405 712 015 916 008 002 115 224 324 126 326 826 228 430 632 435 437 903 407 505
Posted on Sep 25, 2008
The Dish TV remote control
allows you to program the TV, VCR and DVD codes so that all you need is one
remote. Most TVs can be programmed into the remote using specific codes in the
Dish TV remote manual. But if you don't have a manual or list of codes, you can
program the remote manually.
Instructions
1. Using Programming Codes
Find the TV code for
your TV in the list from the Platinum Remote Control User's Guide (See
References). For example, if you have a Kenwood TV, the three possible codes to
try are 506, 573 and 712.
Press the "TV"
button on the remote. Hold down the button until the "Sat,"
"VCR" and "Aux" buttons light up. Release the
"TV" button and it will be flashing.
Enter the first code
using the keypad. If you want the remote to control all functions on the TV,
enter the code and press the # key. The "TV" button will flash three
times.
Press the power button
to turn off the TV and turn it back on again. If the code was correct, the TV
will turn off and on. If the TV doesn't power down or back on, follow Step 6.
Try the next code from the
list. Follow Steps 2 through 4 using each code until one turns off the TV.
2. Programming Without Codes
Press the "TV"
Press and release the
"Power" button on the remote.
Press the arrow up key and
stop. If the TV doesn't turn off, press the arrow up key again. Continue
pressing the arrow up key until the TV turns off. Do not go fast when moving
through the codes or you could miss the correct code. Press the arrow key and
wait at least 20 seconds to see if the code works before pressing the arrow key
again.
Press the # button on the remote control when the TV turns off ot lock the code.
For codes and more details, Visit this site for more details. The site name is (Electro-help). Just type in
"electronicshelponline.blogspot" into the search box of your browser, and click
search. You can see a site by this
name. Pull up older posts there.
Sometimes, ads related to each post might give you details about the
availability of spare parts and price.
It is a blogspot site, in English Language
