oh, OK, I saw that but was thinking that was for only out of warranty work...great!oh, OK, I saw that but was thinking that was for only out of warranty work...great!
You can't post conmments that contain an email address.
As soon as the camera is switched on, the lens barrel will come out. Everything should be ready to shoot pictures. If it is not responding to the buttons, you could try to remove the battery for a few moments. It will cause the camera, to start from scratch. Call it a cold boot. But then after switching on, it should respond normal, like you used to work with it. If it stays frozen, visit your dealer or contact a Samsung certified repair centre.
Turn camera off, remove battery's and sd card. With everything out turn it to the on position for about 2-3. After 2-3 minutes put batterys back in while on the on position. Once he says no card or no memory turn the camera off put sd card back in and test the camera.
Seems that your battery is good but your electronics have gone bad. But just to be on safe side you might try another battery since a battery that does not charge fully could be responsible for erratic electronic operation of components.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have
a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
The problem is a small toggle switch inside the keyslot where the battery access door goes into. I am not sure yet why it quits getting triggered, but taking the camera apart and bypassing this swich will fix the problem. You can check to see if this is your problem without taking the camera apart by opening the access door and sticking a small screwdriver into the keyslot and flipping (gently) the little white toggle toward the back of the camera and then turning the camera on with the power button. If it comes on then the switch is your problem. I assume they put this switch in to kill power when when the access door is opened so that the camera doesn't get double power when a usb cable is plugged in (I imagine you will FRY your camera if you bypass this switch and then forget and plug in the usb without popping out the battery pack). There are eight screws that hold the cover on the back of the camera, you have to pry out those little pink pegs and then you will need a triangle bit to remove the security screws to access the inside of the camera. The two wires (red and orange) are the two that need to be connected to bypass the switch. write on the bottom of the battert pack (remove before plugging in usb) if you do this modification so you remember to remove battert power before pluggin in the usb. If you don't know what you are doing then I would suggest letting someone with some electronics experience do this.
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
If the batteries are a common type, install them into another device to see if they really are still OK or buy a cheap digital multimeter or battery tester.
The latter can be bought at the chain hardware stores or Radio Shack and draw some current to lightly test the load capabilities of them.
These batteries do fail to a short; NICads are the worst but lithium ion and NiMh can fail as well.
The 'sand' diagnosis may be right but what you describe could still be only batteries.
TIPS: 1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery 2.) Remove front plate (screw driver may be needed) 3.) Check all gears, make sure they are correctly fitted in place) 4.) Move the gear manually to make the lens come out. 5.) keep it out, put the front plate back together. 6.) reinsert the battery, turn it on.
or... 1.) Remove the battery. 2.) Wait about 6-8 hours. 3.) Reinsert the battery.
or... 1.) Remove the battery. 2.) Try hooking it up through AC adapter, put correct voltage. 3.) Try turning it on. 4.) Remove AC adapter, reinsert battery. 5.) Turn it on.
