If the primer buld is hard to push or wont return to shape like its supposed to then there is an obstruction in the carb. If it just wont move fuel then there is a hole in the fuel line or the fuel line is rotted off in the tank. If the primer bulb itself is discolored ( should be clear not brown) it should also be replaced.
if it satys running after u do that it sounds like you have a crack in your primmer bulb or a cloged line either one is cheap and easy to fix if it is the primmer bulb it is baout 5 dollers and u will need to go to a a dealer shop and get it if you do need a prime bulb make sure to fup a little vasiline on the edge of the buld it makes it easier to install hope that helps you out.
i own an old Cbr 600 and its probably located near the left front fairing inner panel. but theres also a cannon plug that i had to connect up when i changed out the whole indicator unit..check that also...maybe its loose. hope this helps. can i get a rating...thanks!
contact southern supply company at 205-833-2525 or email them at [email protected] and I feel sure Jason or someone there can help you.You will need to tell them the brand and model of the carb on the unit.
To me it sounds like your line is clogged. It pumps towards the tank but not towards the carb. Open it up, and check your lines out, if it's clogged it could be a little too much oil (just saying if it smokes alot when it's on).
Manual transmission? If we're talking about a neon MT in your 2gnt, what you need to do is take off the bellhousing on both transmissions. put your bellhousing on the neon tranny. also swap your vehicle speed sensor and reverse light switch onto the neon trans. you shouldn't need to mess with any wiring.
