Jeep 2002 Liberty Limited Edition Logo
V
Val Vassell Posted on Jun 09, 2015
Do I have to remove the bolt securing the Idle Sprocket to make tool 8429 flush against the surface of the sprocket so the 4 tines extend pass the camshaft chains
1 Related Answer
nobody322
_-__-___-_
  • 20706 Answers
  • Posted on Jun 08, 2015
SOURCE: how to lock the secondary timing chain to the idle sprocket using tool 8429? Do one has to remove the idle sprocket bolt?
are you reading the fsm?
what are you doing. what job, must be guess that?]
new cam, sprockets , or what was the job....
new heads?
what?
btw we make or own locking tools from scratch.
or uses generic tools.
id need to see what job is going on here.
heck if forgot the link.
here are 2 links
1st is the 16buck, alldata.com
discounted.....
https://www.scantool.net/software/alldata-diy-1-month-subscription.html
pay the money , log in and read.
then here.
real FSM
https://www.techauthority.com/en-US/Pages/Home.aspx
and lst here.
this car is the KJ
see the KJ here.
http://colorado4wheel.com/manuals/Jeep/KJ/
its free too.
there , ive show the top 3 places..
Testimonial: "Firefox will not allow me to download your response, so I'm unable to critique your instruction. Can you send it to my email or post it."
1helpful
How to lock the secondary timing chain to the idle sprocket using tool 8429? Do one has to remove the idle sprocket bolt?
new heads?
what?
here are 2 links
discounted.....
then here.
real FSM
and lst here.
this car is the KJ
see the KJ here.
its free too.
Timing jeep cherockee
double posted but this time the CAM pops up.
why not read the FSM first. ? linked below.
or alldata.com . log in and read.
here ill do a paste from JUST install PART chapter.
you are doing ALL THAT book free, REALLY?
  1. Using a vise, lightly compress the secondary chain tensioner piston until the piston step is flush with the tensioner body. Using a pin or suitable tool, release ratchet pawl by pulling pawl back against spring force through access hole on side of tensioner.
  2. While continuing to hold pawl back, Push ratchet device to approximately 2 mm from the tensioner body. Install Special Tool 8514 lock pin into hole on front of tensioner. Slowly open vise to transfer piston spring force to lock pin.
  3. Position primary chain tensioner over oil pump and insert bolts into lower two holes on tensioner bracket. Tighten bolts to 250 inch lbs. (28 Nm).
  4. Install right side chain tensioner arm. Install Torx®bolt. Tighten Torx®bolt to 250 inch lbs. (28 Nm). CAUTION The silver bolts retain the guides to the cylinder heads and the black bolts retain the guides to the engine block.
  5. Install the left side chain guide. Tighten the bolts to 250 inch lbs. (28 Nm).
  6. Install left side chain tensioner arm, and Torx®bolt. Tighten Torx®bolt to 250 inch lbs. (28 Nm).
  7. Install the right side chain guide. Tighten the bolts to 250 inch lbs. (28 Nm).
  8. Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8429 to hold chains in place for installation.
  9. Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket.
  10. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket.
  11. Lubricate idler shaft and bushings with clean engine oil. NOTE The idler sprocket must be timed to the counterbalance shaft drive gear before the idler sprocket is fully seated.
  12. Install all chains, crankshaft sprocket, and idler sprocket as an assembly . After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or equivalent. This will maintain tension on chains to aid in installation. Align the timing mark on the idler sprocket gear to the timing mark on the counterbalance shaft drive gear, then seat idler sprocket fully . Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 25 ft. lbs. (34 Nm). NOTE It will be necessary to slightly rotate camshafts for sprocket installation.
  13. Align left camshaft sprocket "L" dot to plated link on chain.
  14. Align right camshaft sprocket "R" dot to plated link on chain. CAUTION Remove excess oil from the camshaft sprocket bolt. Failure to do so can result in over torque of bolt resulting in bolt failure.
  15. Remove Special Tool 8429, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
  16. Verify that all plated links are aligned with the marks on all sprockets and the "V6" marks on camshaft sprockets are at the 12 o'clock position. CAUTION Ensure the plate between the left secondary chain tensioner and block is correctly installed.
  17. Install both secondary chain tensioners. Tighten bolts to 250 inch lbs. (28 Nm). NOTE Left and right secondary chain tensioners are not common.
  18. Remove all locking pins from tensioners. CAUTION After pulling locking pins out of each tensioner, DO NOT manually extend the tensioner(s) ratchet. Doing so will over tension the chains, resulting in noise and/or high timing chain loads.
  19. Using Special Tool 6958, Spanner with Adaptor Pins 8346, tighten left and right . camshaft sprocket bolts to 90 ft. lbs. (122 Nm).
  20. Rotate engine two full revolutions. Verify timing marks are at the follow locations: ² primary chain idler sprocket dot is at 12 o'clock ² primary chain crankshaft sprocket dot is at 6 o'clock ² secondary chain camshaft sprockets "V6" marks are at 12 o'clock ² counter balancer shaft drive gear dot is aligned to the idler sprocket gear dot.
  21. Lubricate all three chains with engine oil.
  22. After installing all chains, it is recommended that the idler gear end play be checked. The end play must be within mm 0.004-0.010 inches (0.10-0.25). If not within specification, the idler gear must be replaced.
  23. Install timing chain cover and crankshaft damper.
  24. Install cylinder head covers. NOTE Before installing threaded plug in right cylinder head, the plug must be coated with sealant to prevent leaks.
  25. Coat the large threaded access plug with Mopar® Thread Sealant with Teflon, then install into the right cylinder head and tighten to 60 ft. lbs. (81 Nm).
  26. Install the oil fill housing.
  27. Install access plug in left cylinder head.
  28. Install power steering pump.
  29. Fill cooling system.
  30. Connect negative cable to battery.
Diagram timing of v6 engine of liberty 2001 model
2001 , no such ani-mule !
"Introduced for the 2002 model year as a replacement for the Cherokee (XJ),"
you meant manufactures date not model and reg. date. sure.
2002 !
3.7L V6 (cop spark ) chain drive cams....
timing ( cam or spark?)
"Ignition timing is controlled by the Powertrain Control Module (PCM). No adjustment is possible"
so Cam timing (alldata.com covers this in detail)
why not post the context, Im doing what.?
im doing a 60k belt swap
or it slipped. or think id did.
or just put in a new head or cam? see , context is 100% important.
im here, going to there.....
im on line, and it shows 4 engines, i think that is wrong, but...
you must be asking chain cam sprocket timing.
im at alldata.com (or FSM)
there are 37 install steps, im not sure what step you want me
to pluck out. but here is my guess. step 8 ,9,10
  1. Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8429 to hold chains in place for installation.
  2. Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket.
  3. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket.
step 12:
step 13:
  1. Align left camshaft sprocket "L" dot to plated link on chain.
  2. Align right camshaft sprocket "R" dot to plated link on chain.
step 15/16
  1. Remove Special Tool 8429, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
  2. Verify that all plated links are aligned with the marks on all sprockets and the "V6" marks on camshaft sprockets are at the 12 o'clock position.
do ask questions, or login to alldata.com or mitchels
or get a real FSM.
its nothing trivial.
in fact get the book before the job. so are perpared.
I am changing the timing chain in a 1993 Chevy S-10 with a 4.3L engine. I was told you have to disconnect a wire to reset it but I don't know where the wire is.
Timing Chain: Service and Repair
REMOVAL
Tools Required = Crankshaft Sprocket Puller
1. Remove the timing cover.
2. Remove the crankshaft position sensor reluctor ring.
3. Remove the camshaft sprocket bolts.
4. Remove camshaft sprocket.
5. Remove timing chain.
6. Remove the crankshaft sprocket.
7. Remove crankshaft sprocket key.
INSTALLATION
1. Install the key into the crankshaft keyway.
2. Use the crankshaft balancer installer to install the crankshaft sprocket.
3. Install the camshaft sprocket and timing chain.
4. Install camshaft sprocket bolts.
Be sure to align the camshaft and the crankshaft sprocket marks. Timing marks (Number 4 Firing).
Tighten bolts to 21 ft. lbs.
5. Align the keyway on the reluctor ring with the key in the crankshaft.
6. Install the reluctor ring onto the crankshaft until the ring is completely seated against the crankshaft sprocket.
7. Install the timing cover.
Don't know what Wire you are referring to.
Change the water pump
  • Tools Required
  • J 43651 Water Pump Holding Tool
  • Remove the thermostat housing.
  • Remove the water pump access plate from the front cover.
  • Remove the right hand fender liner.
    1. Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
    Drain the coolant from the water pump using the plug at the bottom of the pump.
    1. mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
    Install the J 43651 into position.
    1. Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
    2. Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
    3. Remove the 3 inner water pump sprocket to water pump blots.
      1. Important: Be sure to remove both water pump bolts from the front of the engine block.
      Remove the 2 water pump bolts.
      Remove the rear 2 water pump bolts.
      1. Remove the water pump.
      2. Remove and discard the water pump O-ring seal.
      Installation Procedure
      1. Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
      Install a NEW water pump O-ring seal.
      1. Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
      Using the guide pin, align the pin with the water pump holding tool.
      1. Position the water pump against the engine block and hand tighten the water pump bolts.
      2. Notice: Refer to Fastener Notice.
      Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt.
      Tighten the bolts to 25 Nm (18 ft. lbs.).
      1. Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
      2. Remove the J 43651.
      3. Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
      4. Install the right hand fender liner.
      5. Install the thermostat housing.
How to reset timeing on a 1991 chevy lumina 3.1
Timing is not resettable by the user, as the computer controls this based on knock or no knock conditions which will advance or ****** ignition timing for optimum performance.
The valve timing is something that is set when installing the timing chain:
2.5L, 2.8L and 3.1L Engines Fig. 4: Timing chain and sprocket removal - 2.5L engine 88003ga8.gif
Fig. 5: Timing chain and sprocket removal - 1996 3.1L engine shown 88003gb5.gif
Fig. 6: You must use a suitable puller to remove the crankshaft sprocket 88003gb6.gif
  1. Disconnect the negative battery cable.
  2. Remove the timing chain front cover assembly, as outlined earlier in this section.
  3. Rotate the crankshaft until the timing marks on the crankshaft sprocket and camshaft sprocket locator hole are aligned to the marks on the engine block or timing chain dampener. This is the No. 1 piston at TDC (No. 4 firing position).
  4. Unfasten the camshaft sprocket retaining bolt/screw, then remove the camshaft sprocket and the timing chain. NOTE: If the camshaft sprocket does not come off easily, a light blow on the lower edge of the sprocket with a rubber mallet should loosen the sprocket.
  5. Remove the crankshaft sprocket using tool J 23444-A or equivalent puller.
  6. If necessary, remove the timing chain dampener retaining bolts, then remove the dampener. To install:
  7. Install the crankshaft sprocket using tool J 38612 until it the sprocket is fully seated on the flange of the crankshaft nose. Apply a coat of Molykote® or equivalent, to the sprocket thrust surface.
  8. Hold the camshaft sprocket with the chain hanging down, and align the marks on the camshaft and crankshaft sprockets.
  9. If removed, install the timing chain damper to the engine block.
  10. Align the dowel in the camshaft with the dowel hole in the camshaft sprocket. Install the camshaft sprocket and chain, use the camshaft sprocket bolts to draw the sprocket on to the camshaft. Tighten the sprocket bolts to 18 ft. lbs. (25 Nm).
  11. Lubricate the timing chain with engine oil.
  12. Install the front cover assembly, as outlined earlier in this section.
  13. Connect the negative battery cable.
2helpful
Installing a timing belt
Timing Belt and Sprockets REMOVAL & INSTALLATION Fig. 1: If you plan on reusing the timing belt, make sure you note the direction of the rotation before removal 91053p69.jpg Fig. 2: If the special tool is unavailable, a suitable length and width straight edge can be used to align the camshafts 91053p10.jpg Fig. 3: Camshaft alignment using the special service tool 91053g61.gif Fig. 4: Insert the crankshaft damper bolt to turn the crankshaft and . . . 91053p64.jpg Fig. 5: . . . align the camshafts and the . . . 91053g64.gif Fig. 6: . . . crankshaft before removing the old belt 91053p66.jpg Fig. 7: Loosen the timing belt tensioner pulley bolt, slide the tensioner back and . . . 91053p67.jpg Fig. 8: . . . tighten the bolt to the farthest right hand side as possible to hold the release the tensioner pulley so that the belt can be removed 91053p68.jpg Fig. 9: . . . remove the belt starting from around the camshaft pulleys 91053p01.jpg Fig. 10: Installation of the tensioner spring and retaining bolt 91053g62.gif For information on timing belt recommended replacement interval, refer to Section 1. CAUTION
The 2.0L engine is an interference motor. Extending the replacement interval could lead to the belt breaking and severe and costly engine damage. Care must be taken if rotating the crankshaft or camshafts with the belt off, if resistance is felt, do not force them to turn.
  2. Remove the timing belt covers as outlined in this Section.
  3. Remove the valve cover.
  4. Place Camshaft Alignment Timing Tool T94P-6256-CH or equivalent, into the slots of both camshafts at the rear of the cylinder head to lock the camshafts into position. NOTE: If the special tool is unavailable, a suitable length and width straight edge can be used to align the camshafts.
  5. Loosen the camshaft timing belt tensioner pulley retaining bolt and move the tensioner pulley to relieve the tension on the timing belt.
  6. Temporarily tighten the tensioner in this position. NOTE: If the timing belt is to be reused, mark the belt for the direction of rotation before removing to prevent premature wear or failure.
  7. Remove the timing belt.
  8. If required, remove the sprockets as follows:
    1. Hold the camshaft with an appropriate camshaft sprocket holding tool.
    2. Loosen and remove the camshaft sprocket retaining bolt.
    3. Remove the sprocket from the camshaft.
    4. Repeat the procedure for the 2nd camshaft sprocket.
    5. Remove the crankshaft sprocket.
  9. Slide the crankshaft sprocket onto the crankshaft aligning the key-way.
  10. Align the camshafts using the Camshaft Alignment Timing Tool T94P-6256-CH. NOTE: If the special tool is unavailable, a suitable length and width straight edge can be used to align the camshafts.
  11. Reinstall the sprockets onto the camshafts and loosely install the camshaft retaining bolts.
  12. Tighten the camshaft sprocket retaining bolts to 47–53 ft. lbs. (64–72 Nm) .
  13. Loosely install the crankshaft pulley to verify that the engine is at TDC. Realign the marks if they have moved.
  14. Verify that the camshafts are aligned. NOTE: It is recommended to purchase a tensioner spring and retaining bolt through the dealer parts to apply the proper tension for used or new belt installations. The spring is bolted to the tensioner assembly and becomes a part of the engine. Ignore this notice if the tensioner spring is already installed.
  15. Reinstall the retaining bolt (W700001-S309) into the hole provided in the cylinder block and place the tensioner spring (6L277) between the bolt and the camshaft timing belt tensioner pulley.
  16. Tighten the retainer bolt to 71–97 inch lbs. (8–11 Nm) .
  17. Remove the crankshaft pulley and install the timing belt onto the crankshaft sprocket, then onto the camshaft sprockets working in a counterclockwise direction.
  18. Tighten the camshaft sprocket retaining bolts to 47–53 ft. lbs. (64–72 Nm) .
  19. Be sure that the span of the camshaft timing belt between the crankshaft sprocket and the exhaust camshaft sprocket is not loose.
  20. Be sure that the camshaft timing belt is securely aligned on all sprockets.
  21. Reinstall the lower timing belt cover and tighten the retaining bolts to 53–71 inch lbs. (6–8 Nm) .
  22. Apply silicone sealer to the key-way of the crankshaft pulley and install. Tighten the retaining bolt to 81–89 ft. lbs. (110–120 Nm) .
  23. Inspect the timing mark on the crankshaft pulley to verify that the engine is still at TDC.
  24. Loosen the camshaft timing belt tensioner pulley retaining bolt and allow the tensioner spring attached to the pulley to draw the tensioner pulley against the camshaft timing belt.
  25. Remove the camshaft alignment timing tool from the camshafts at the rear of the engine.
  26. Turn the crankshaft two revolutions in a clockwise direction.
  27. Tighten the camshaft timing belt tensioner pulley retaining bolt to 26–30 ft. lbs. (35–40 Nm) .
  28. Recheck that the crankshaft timing mark is at TDC for the No. 1 piston, and that both camshafts are in alignment using the camshaft alignment timing tool. NOTE: A slight adjustment of the camshafts to allow the insertion of the camshaft alignment timing tool is permissible as long as the crankshaft stays at the TDC location.
  29. An appropriate camshaft sprocket holding tool can be used to move the camshaft sprocket (s) if a slight adjustment is required.
  30. If a camshaft is not properly aligned, perform the following procedure:
    1. Loosen the retaining bolt securing the sprocket to the camshaft while holding the camshaft sprocket from turning with the sprocket holding tool.
    2. Turn the camshaft until the camshaft alignment timing tool can be installed.
    3. Verify that the crankshaft timing mark is at TDC for the No. 1 cylinder.
    4. While holding the camshaft sprocket with the camshaft sprocket holding tool, tighten the retaining bolt to 47–53 ft. lbs. (64–72 Nm) .
    5. Remove the tool and rotate the crankshaft two revolutions (clockwise) .
    6. Verify that the camshafts are aligned and that the crankshaft is at TDC for the No. 1 cylinder.
  31. Install the valve cover.
  32. Install the timing belt covers.
2helpful
How i fix timing of lantra 1600 cc 95
Disconnect battery earth lead. Do not turn crankshaft or camshaft when timing belt removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of ratation unless otherwise stated, Support engine. Remove, engine mounting, auxilliaty drive belts. Water pump pulley 1. Crankshaft pulley bolts 21. crankshaft pully 2. timing belt covers 3. Turn crankshaft to TDC on No 1 cyclinder. Ensure crankshaft sprocket, camshaft sprocket, oil pump sprocket and balancer shaft sprocket timing marks aligned. Timing marks on camshaft sprockets should align with cylinder head upper face. Dowel pins on camshaft sprockets should face upwards. Slacken tensioner bolt. Move tensioner away from belt and lightly tighten bolt. Remove, automatic tensioner unit bolts. Automatic tensioner unit. Timing belt, crankshaft centre bolt, crankshaft sprocket. Crankshaft sprocket guide washer. Slacken blancer shaft belt tensioner bolt. Move tensioner away from belt and lightly tighten bolt. Remove balancer shaft belt.
Installation
Ensuring timing marks arligned. Note timing marks on camshaft sprockets should align with cylinder head upper face. Exhaust sprocket mark is on recess, but inlet sprocket mark is on tooth. Note: to check oil pump sprocket positioned correctly, removing blanking plug from cylinder block. Insert 8mm diameter Phillips srcrewdriver in hole. Ensure screwdriver is inserted 60mm from face of cylinder block. if screwdriver can only be inserted 20mm: turn oil pump sprocket 360°. Insert screwdriver again. Fit balancer shaft belt in anti-clockwise direction, starting at crankshaft sprocket. Slacken balancer shaft belt tensioner bolt. Turn tensioner clockwise to tension belt. Tighten bolt to 15-22Nm. Apply thumb pressure to belt. Belt should deflect 5-7 mm. If not repeat tensioning procedure. Install crankshaft sprocket guide washer, crnakshaft sprocket. Tighten crankshaft cente bolt. Tighten torque:110-130 Nm. Note ensure crankshaft sprocket guide washer is fitted correclty. Oil treads and contact face of crankshaft body before fitting. Check tensioner body for leakage or damage replace if necessary. Check pushrod protrusion is 12mm. If not replace automatic tensioner unit. Slowly compress pushrod into tensioner body until holes aligned. Resistance should be felt. Place flat washer under tnesioner body to avoid damage to body end plugs. Retain pushrod with suitable pin through hole in tensioner body. install automatic tensioner unit to cylinder block. Tighten bolts to 22-27Nm. Fit timing belt in anti-clockwise direction, starting at the tensioner pulley. Slacken tensioner pulley bolt. Turn tensioner pully clockwise to temporarily tension belt. Tighten bolts to 43-45Nm. Turn crankshaft slowly 1/4 turn anti-cockwise. Turn crankshaft clockwise until timing marks alligned. Slacken tensioner pully bolt. Fit tool to tensioner pulley. Tool No 09244 28100. Apply clockwise torque of 2,6-2,8 Nm to tensioner pulley. Tighten bolt to 43-45Nm. Insert special tool in timing belt rear casing. Tool no 09244-28000. Screw in tool until pin can be removed from automatic tensioner unit. Remove special tool. Tool nr 09244-28000. turn crankshaft two turns clockwise. Wait 15 minutes. Ensure timing marks aligned. Check extended length of pushrod is 3,8-4,5mm. Install components in reverse order of removal. Tighten crankshaft pulley bolts, Tighten torque 20-30Nm
1helpful
Timming belt broke on 93 plymouth lazer and need instalation directions
It is recommended that the timing belt be replaced periodically to assure correct engine performance. Because of their composition, timing belts wear over a period of time and mileage. To avoid vehicle break down and possible engine damage, the manufacturer recommends timing belt replacement at 60,000 miles.
REMOVAL & INSTALLATION1.8L Engine
See Figures 1, 2 and 3
  1. If possible, position the engine so the No. 1 piston is at TDC.
  2. Disconnect the negative battery cable.
  3. Remove the timing belt covers.
  4. Remove the timing (outer) belt tensioner and remove the outer timing belt.
  5. Remove the outer crankshaft sprocket and flange.
  6. Remove the silent shaft (inner) belt tensioner and remove the belt.
Fig. 1: Silent shaft belt timing marks-1.8L engine
Fig. 2: Checking the silent shafts for proper positioning
Fig. 3: Timing belt timing mark alignment-1.8L engine
To install:
  1. Align the timing marks of the silent shaft sprockets and the crankshaft sprocket with the timing marks on the front case. Wrap the timing belt around the sprockets so there is no slack in the upper span of the belt and the timing marks are still aligned.
  2. Install the tensioner pulley and move the pulley by hand so the long side of the belt deflects about 1 / 4 in.
  3. Hold the pulley tightly so the pulley cannot rotate when the bolt is tigthened. Tighten the bolt to 15 ft. lbs. (20 Nm) and recheck the deflection amount.
  4. Install the timing belt tensioner fully toward the water pump and tighten the bolts. Place the upper end of the spring against the water pump body.
  5. Align the timing marks of the camshaft, crankshaft and oil pump sprockets with their corresponding marks on the front case or rear cover.
There is a possibility to align all timing marks and have the oil pump sprocket and silent shaft out of time, causing an engine vibration during operation. If the following step is not followed exactly, there is a 50 percent chance that the silent shaft alignment will be 180 degrees off.
  1. Before installing the timing belt, ensure that the left side (rear) silent shaft (oil pump sprocket) is in the correct position as follows:
    1. Remove the plug from the rear side of the block and insert a tool with shaft diameter of 0.31 in. (8mm) into the hole.
    2. With the timing marks still aligned, the shaft of the tool must be able to go in at least 2 1/2 in. If the tool can only go in about 1 in., the shaft is not in the correct orientation and will cause a vibration during engine operation. Remove the tool from the hole and turn the oil pump sprocket 1 complete revolution. Realign the timing marks and insert the tool. The shaft of the tool must go in at least 2 1/3 in.
    3. Recheck and realign the timing mark.
    4. Leave the tool in place to hold the silent shaft while continuing.
  2. Install the belt to the crankshaft sprocket, oil pump sprocket, then camshaft sprocket, in that order. While doing so, make sure there is no slack between the sprocket except where the tensioner is installed.
  3. Recheck the timing marks' alignment. If all are aligned, loosen the tensioner mounting bolt and allow the tensioner to apply tension to the belt.
  4. Remove the tool that is holding the silent shaft and rotate the crankshaft a distance equal to 2 teeth on the camshaft sprocket. This will allow the tensioner to automatically apply the proper tension on the belt. Do not manually overtigthen the belt or it will howl.
  5. Tigthen the lower mounting bolt first, then the upper spacer bolt.
  6. To verify correct belt tension, check that the deflection at the longest span of the belt is about 1 / 2 in.
  7. Install the timing belt covers and all related items.
  8. Connect the negative battery cable.
2.0L Engine
1990-94 VEHICLES
See Figures 4, 5, 6 and 7
  2. Remove the timing belt upper and lower covers.
  3. Rotate the crankshaft clockwise and align the timing marks so No. 1 piston will be at TDC of the compression stroke. At this time the timing marks on the camshaft sprocket and the upper surface of the cylinder head should coincide, and the dowel pin of the camshaft sprocket should be at the upper side.
Always rotate the crankshaft in a clockwise direction. Make a mark on the back of the timing belt indicating the direction of rotation so it may be reassembled in the same direction if it is to be reused.
  1. Remove the auto tensioner and remove the outermost timing belt.
Fig. 4: Exploded view of the timing belt and sprockets-1990-94 2.0L engines
  1. Remove the timing belt tensioner pulley, tensioner arm, idler pulley, oil pump sprocket, special washer, flange and spacer.
  2. Remove the silent shaft (inner) belt tensioner and remove the belt.
  3. Remove the crankshaft retaining bolts, then remove the pulley.
  4. Remove the crankshaft sprocket retainer bolt and washer from the sprocket, if used, and remove the sprocket. If the sprocket is hard to removed, the proper puller may be used. If no bolts are used on the sprocket. Use the correct puller to remove.
  5. Hold the camshaft stationary using the hexagon cast between journals No. 2 and 3 and remove the retainer bolt. Remove the sprocket from the camshaft.
To install:
  1. Install the sprockets to their appropriate shafts. Install the retainer bolts and tighten the camshaft sprocket bolt to 65 ft. lbs. (90 Nm).
  2. Check both tensioner and idler pulley for bearing wear, and replace if needed.
  3. Align the timing marks on the crankshaft sprocket and the silent shaft sprocket. Fit the inner timing belt over the crankshaft and silent shaft sprocket. Ensure that there is no slack in the belt.
Fig. 5: Align the camshaft sprocket so marks face each other and are in alignment with the top surface of the cylinder head-1990-94 2.0L engine
Fig. 6: Align the crankshaft timing mark and the oil pump sprocket timing mark-1990-94 2.0L engine
Fig. 7: Timing marks in alignment-1990-94 2.0L engine
  1. While holding the inner timing belt tensioner with your fingers, adjust the timing belt tension by applying a force towards the center of the belt, until the tension side of the belt is taut. Tighten the tensioner bolt.
When tightening the bolt of the tensioner, ensure that the tensioner pulley shaft does not rotate with the bolt. Allowing it to rotate with the bolt can cause excessive tension on the belt.
  1. Check belt for proper tension by depressing the belt on its' long side with your finger and noting the belt deflection. The desired reading is 0.20-0.28 in. (5-7mm). If tension is not correct, readjust and check belt deflection.
  2. Install the flange, crankshaft and washer to the crankshaft. The flange on the crankshaft sprocket must be installed towards the inner timing belt sprocket. Tighten bolt to 80-94 ft. lbs. (110-130 Nm).
  3. To install the oil pump sprocket, insert a Phillips screwdriver with a shaft 0.31 in. (8mm) in diameter into the plug hole in the left side of the cylinder block to hold the left silent shaft. Tighten the nut to 36-43 ft. lbs. (50-60 Nm).
continue...
2answers
Honda accord ex 92
Crankshaft pulley (harmonic balancer) removal- disconnect neg battery cable, remove belts, it would be a good idea to soak the bolt w/ penetrating oil overnight, there is a special 'crankshaft pulley holding tool' available to secure the pulley while removing and installing the bolt. Some parts stores loan tools for free if u purchase parts from them, I don't know if this is available, but it would be worth checking out. Attach holding tool and remove bolt securing pulley. Carefully remove pulley from crankshaft, Do NOT pry off. Remove key from crankshaft sprocket,
Install: install key on crankshaft sprocket, slide pulley on, apply clean oil to bolt threads but NOT to washer contact surfaces, secure crankshaft w/ holding tool, tighten to 159 ft lbs (91-93 Accord), install belts, re-attach neg cable.
Top Jeep Toys Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Jeep Toy Expert? Answer questions, earn points and help others
