Hello, Is it possible to connect this MIDI interface tot an Android tablet. I would have a MIDI-file on the tablet that plays through the interface on a digital piano.
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface:
- you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
Transfer the data in MIDI format. The BUP format is a proprietary format to the keyboard and can ONLY be played by the keyboard. Either dump the data as MIDI format or using a MIDI interface send it to the PC or lastly, capture the audio using an audio interface on the PC.
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
we should have a mic pin and audio cable as shown in this pic
connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
if the mpc has GM soundbank then this should be possible. You might be better off recording the audio from a suitable GM unit first of all before gigging with it, then you can make it sound the way you want and change the key to suit etc.
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
