Check the power source: Make sure the treadmill is properly plugged into a working outlet, and check that the circuit breaker or fuse is not tripped.
Check the safety key: The safety key is a small plastic key that is inserted into the console to allow the treadmill to operate. Make sure that the key is properly inserted and that the key is not worn or damaged.
Check the console: Make sure that the console is properly connected to the treadmill, and that the console is not damaged or malfunctioning.
Check the belt: Make sure that the belt is properly aligned and tensioned. If the belt is loose or out of alignment, it can cause the machine to reset.
Check the motor: If the above steps do not fix the problem, the motor may be malfunctioning and needs to be repaired or replaced.
Check the control board: If the above steps do not fix the problem, the control board may be malfunctioning and needs to be repaired or replaced.
DISPLAY SHOWS MALFUNCTION 8
Solution: Turn off and unplug machine. Wait a minute. Turn machine on and wait until it stops making any noise. Now try to pull out the drawer. If this does not work, try the procedure again. If this does not work, call customer service
Regards Kat (please leave feedback, many thanks)
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed. Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
I had the same spout malfunction proiblem. I never give up and I always manage to fix these kinds of things. I read this board called the company, they are clueless. Here is your answer: Remove the brewing unit and get a pair of pliers. With the pliers, gently jolt the the circular gearbox that rotates the brewing unit at the bottowm of the machine. It is the left hole of the 2 holes inside the unit on the bottom Gently move it clockwise. You will hear the gears make a faint noise like the machine does when it is on and spinning the brewing unit.
Now replace the unit and turn on the machine. Magic, the spout malfunction issue is gone and the machine works again. I had to do this several times before it worked. Apparently the spuse malfunction has something to do with aligning the dear box in the unit with the removable brew unit., Of course make sure the brew unit is aligned with the yellow marks before you replace it into the unit.
