Question about Magic Chef MCWC30MCG Compact Wine Cooler
I have a MagicChef wine cooler that stopped working. Compressor and fan do not run although there is power to the unit since the light turns on. Compressor is hot to the touch.
Posted by Mark Covello on
wcthomas01
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Your unit needs to have a new capacitor possibly. However, it will be next to impossible to find someone who will check it out and get the right one for this unit. Unless the unit is under warranty, I would suggest trying to get the retailer to replace it at no cost to you. If under warranty, the manufacturer should make it right? if both of those avenues are not available, then I would suggest get a new unit.
Posted on Jun 09, 2015
  • Mark Covello
    Mark Covello Jun 11, 2015
    Thank you for your answer. Is there another term for a capacitor? In the electric schematic it identifies the PTC Starter, Thermostat, Overload Protector and the Compressor. Could it be the PTC Starter or Overload Protector? Thank you.
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
It just stopt cooling ([email protected])
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
I have a Avanti wc492d wine cooler that is not working. The unit shows power(lights are working) but it will not cool at all. I can here a click sound when I change the temp set, but the cooler will not...
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti WC492D Wine Cooler
The wine cooler light works but it does not cool.
so the light tell us that it has power . you need to ck the fan underneath in back and make sure it is running and feel the compressor it runs when the fan does . and you may nees gas in the unit . . so ck the fans / then the compressor see if hot or can you feel it running and then the refergent . and the thermostat down in front . andy of these could cause the no cool problem. mm hope this has helped ..feed back pls ..
Nov 25, 2010 | GE ZDW24Y Wine Cooler
FR23SL Uses Peltier Cooling - No compressor nor freon....
Luzer - Thanks for the very helpful solution. My cooler has the problem described. When I take off the back and plug it back in, all three fans run, but the unit does not get cold. Is it possible that it needs new fans anyway (like maybe they are going but not moving enough air to generate the effect)? Or woudl it be something else?
Thanks!
Mar 25, 2010 | Emerson (025806803716) Wine Cooler
Wine cooler just stopped working. light will come
Try disconnecting all power to the unit for about 10 mins, and turn it back on to see if the compressor will kick in. Also check your temp settings and make sure they are properly set. If that doesnt work, you might have a dead compressor which a tech can look at and verify.
DrakeTech.
Mar 01, 2010 | KitchenAid KUWS246E Stainless Steel Wine...
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
The compressor and the fan don't run.
its your contactor or the wire feeding it
Aug 16, 2009 | GE ZDW24A Wine Cooler
I just bought a wine cooler not sure where to start to fix it. Fans will not turn on
Hi there.........i take it this is a used / second hand wine cooler......if so you've probably discovered why its been discarded........problem could b due to a faulty compressor unit....the fans are usually wired through the compressor...and run in conjunction with it........if the compressor isnt running then the fans are out .........if the comressor is running then check that there is nothing impeeding the fans rotation.....check for broken or damaged wiring.....check for tampering by someone else....check continuity of wiring through fan coils.........check for faulty starter unit on compressor
regarddss ir Galahad
Aug 12, 2009 | Haier BC112G Wine Cooler
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
Magic Chef MCWC30MCG Compact Wine Cooler Logo
413 people viewed this question
Top Magic Chef Furniture Experts
Sheldon Dedek
Muntejaya Ginting
Muntejaya Ginting
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
