Question about Psi Garden
Where can I buy a replacement hose for my King Craft 2400 PSI PRESSURE WASHER. All I see is 2200 PSI.
Mister Danger
  • 5,631 Answers
Ask them if 2200 psi works for 2400 psi
Posted on Jun 07, 2015
5 Related Answers
Anonymous
  • 104 Answers
SOURCE: Cant get any pressure build up... acts like a hose to water flowe
looks like you will have to get the diaphragm seals in the pump replaced
Posted on May 23, 2009
Anonymous
  • 90 Answers
SOURCE: karcher 2400 psi washer- no pressure
if the water is flowing
the valves need to change
if no water pistons in pump need to change.
Posted on Aug 01, 2009
airjoc
Rob Sinbad
  • 709 Answers
SOURCE: Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Posted on Sep 24, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Thanks for using FixYa.
Kelly
Posted on May 04, 2010
Testimonial: "yes - your info was helpful Thanks Greg"
Anonymous
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
How do i change the oil on a king craft 2200 psi pressure washer
Best way to do it is to suck it out with one of those pumps designed to suck engine oil out of a car engine. Or you can try to siphon it out.
Jun 13, 2017 | Psi Garden
What is the price and types of the pressure washers and where can i buy it?
Hi mary
About the price i think Mr JERRY is true
About the types there are many types like : -
- 2000 PSI Electric
- Gentron 2200 PSI Gas Pressure Washer
- Gentron 3000 PSI Gas Pressure Washer
- Gentron 4200 PSI
- 1600 PSI Electric Pressure Washer
- 2000 PSI Electric Pressure Washer
- 2200 PSI Gas Pressure Washer
And about the place you can buy these products, you can find many depots online like : -
http://www.generatordepot.us/pressure-washers.aspx
Thanks
Oct 30, 2011 | Garden
Need a replacement hose for the Blue Max pw2200/03435 power washer (2200 psi)
Check jackssmallenginerepair.com or ereplacementparts.com they should have what you need.
Jul 25, 2011 | Psi Blue Max 2200 High Pressure Gas Power...
Water leak where the gun hose connects to the washer causing very low pressure 2200 psi model 020245
Simple fix, just disconnect house end from washer, buy a new rubber washer o ring, like what is used for garden hoses. Put back on make sure it is tight. If still leaks, then need to replace connection end fitting on preside washer, can get those at almost any hardware store, use plumbers tape on threads when putting new fitting on machine, then connect house and back to those honey do list :)
Jun 08, 2011 | Garden
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
Troy-bilt 2200 psi pressure washer
Jul 09, 2009 | Garden
Garden Logo
343 people viewed this question
Top Psi Garden Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Lawrence Oravetz
Are you a Psi Garden Expert? Answer questions, earn points and help others
