Question about Callaway Golf Callaway 6 Tri-Ball Hitting Net
On golf balls of different makes, I see red numbers, yellow numbers, black numbers etc. Do the different color numbers mean different compression?
All golf balls have numbers on them. Do the different color of the numbers designate hardness or compression?
Mister Danger
  • Callaway Golf Master
  • 5,631 Answers
No blue green yellow like in football peach color flags thrown peach color grass is blue green purple color is black etc etc
Are you using a component video connection (3 wires for the video, colored red, green, and blue)? It sounds as though you are, but correct me if you are using a different connection as the steps will be different. If so, ensure that they are all connected. You can also unplug one at a time while watching the picture. If the colors DON'T change when unplugging any individual wire, then check that wire from end to end looking for cuts/corrosion/etc... If necessary, replace the cable. Also make sure that they're plugged in to the right jacks, they should be color coded. NOTE: there is a red jack for the video AND for the audio. Check carefully that these aren't mixed up.
Nov 08, 2013 | Panasonic TH-42PD50U 42 in. Plasma EDTV
We have a 2002 gas club car golf cart and we need a diagram of the key switch starter and can not find a diagram to show the different colored wire connections
black-ground
yellow-white accesory
red-green- 12v constant.
generic application colors.
use a voltmeter and a 12v light to verify all connections.
Nov 03, 2013 | Dual Club Car Lester Power Drive Charger...
1991 Toyota Camry Ignition harness has different colord wires than those mentioned in the connection tables
Try looking at color codes for the year before and the year after, just never know.
Dec 18, 2017 | 1991 Toyota Camry
Colors of wires of MAF sensor in 2001 VW golf gti vr6
2001 VW Golf GTi VR6
On the MAF sensor connecting plug you will see 5 pin numbers. Each pin number correspond to a wire color:
Pin no.# 1 = violet/green, is comming from pin no.# 26 of ECM. ECM = Engine Control Module.
Pin no.# 2 = blue/yellow, is comming from fuse no.# 43 = 10 Amp. (battery plus is comming through a blue wire from pin no.# 23 of fuel pump relay).
Pin no.# 3 = green, is comming from pin no.# 27 of ECM.
Pin no.# 4 = red/violet, is comming from pin no.# 53 of ECM.
Pin no.# 5 = black, is comming from pin no.# 29 of ECM.
Wiring diagram:
Feb 10, 2012 | Cars & Trucks
1996 eagle vision radio wiring
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Light Blue
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 23, 2009 | 1996 Eagle Talon
Wiring diagram
See if this link is of any help. I know how crazy these new wire colors can be. I don't know why they don't keep it simple and universal meaning all constant power be red, alt power blue/white, ground black, etc. etc. Even my Hyndai has crazy wires. my red is lf speaker, yellow, lr speaker, etc. Goodluck with it man.
http://64.85.6.118/diagrams/diagrams.asp
May 21, 2008 | Car Audio & Video
Pink copies
Most printers is run by 4 colors black and the colored is basically yellow red blue. (or may called it magenta cyan etc)
1. One of you colored ink runs out that why you cant make any colored.
2. Or one of the basic color might be clog up, dry or simply empty.
3. you need all the 3 colors to make all the colors available.
e-mail me at [email protected]
good luck
Apr 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
Callaway Golf Callaway 6 Tri-Ball Hitting Net Logo
1,412 people viewed this question
Top Callaway Golf Golf Experts
ray gallant
Kardoc
Bill Boyd
Are you a Callaway Golf Golf Expert? Answer questions, earn points and help others
