RCA Rt2380bk Home Theater Surround With Universal Remote Controller Logo
w
walter wiggins Posted on Jun 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does this model have hdmi hookup
Tv is rca led46c45rq
Steve Allison
Level 3:
  • RCA Master 5,569 Answers
  • Posted on Jun 06, 2015
Steve Allison
RCA Master
Level 3:
Answers
5569
Questions
Helped
2002551
Points
16452
According to specs listed below, it appears to have two HDMI inputs:
RCA LED46C45RQ 46 Inch LED Lit 1080p 60Hz TV Black
I have a RCA tv model No led46c45rq with no picture , but does have sound
The HDMI cables need to be replaced and does not work for your TV.There is a problem with your TVs HDMI cables.
Dynex DX-LCD37 Audio with HDMI
Try connecting directly instaed of through the switch box.
tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
Rca led46c45rq screen goes black
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Got the digital set up box from Time Warner Cable but they did not include hook-up instructions.
If you have an HDTV, you can hookup HDMI cable from set-top-box to the HDTV's HDMI input and select that input on the TV using your remote. If you have analog TV, you can hookup using RCA cables (yellow to yellow, white to white). You could also call Time-Warner for assistance.
2answers
How do I connect a presario CQ60-211ds to a Philips 42pfl3704d/f7
Hi, I don't know if you have sorted it out, but here goes.
I have a slightly different model to you, but mine has a HDMI output and my TV also has HDMI, just connect the 2 together whith a cheap HDMI cable, not need to spend a fortune and you should be sorted. There is another way and that is using the monitor ( VGA Connector ), but I don't think your TV has a pc input. I have just found this while typing.
http://www.p4c.philips.com/cgi-bin/dcbint/faqview.pl?ctn=42PFL3704D%2FF7&dct=QAC&new_tmpl=1&refdisplay=QAC_72673&refnr=0072673&scy=US&slg=AEN
Give it a read but basically the only connection you can use is hdmi unless you have a dvi connector on you laptop.
I bought a wireless keyboard and mouse and left the laptop near the TV so i can use it from my armchair.
Let me know if this has helped.
Tony
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
1helpful
My ps3 will work on the rca hookups but not on the hdmi hookups
When you hooked up the HDMI did you go into display settings and change all the PS3 settings to HDMI instead of AVI? I thought my HDMI wasnt working, just a blank screen but I could hear the sound, then it hit me..... change the video and display settings to HDMI and poof, there was the pic. lol
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
