Could it be the charger or possibly the camera itself
Hi, Check the connections for tightness and use a volt/ohm meter to check for charging voltage. Anywhere between 6v and 12v. If you suspect charger, replace with same kind and Voltage output.
Also check battery(s). replace if dead. After many battery uses. They can have an internal discharge and will not work properly any more.
Good luck.
