Question about Acer Computers & Internet
Acer Aspire One D257 13450 with windows 7 starter will start up in 5 minutes will freeze control alt delete mouse or curser freezes only way to shut down is hold the power button until it shuts off.
Posted by Valerie Harrison on
Elizabeth E. (M. P. D.)
    New Friend:
  • 4 Answers
Have you checked how much space you have left on your drive? When I went over one time that happend to me..so I deleted 100GB and it was fine after.GOOD LUCK
Posted on Jun 06, 2015
5 Related Answers
Anonymous
  • 2961 Answers
SOURCE: frequent freezing of mouse,and unexpected shut down
the mouse is freezing because, you have either too many programmes running at start up, conflicting drivers, slow start up anti virus programmes, or you may have a virus or trojan/spyware programme running in the background. The shut down could be a processor overheating problem, so check all your vents and fans for clogged up dust and ensure your pc is well ventillated.
Posted on Apr 01, 2007
Anonymous
  • 108 Answers
SOURCE: mouse keeps freezing
It maybe getting too hot. You need to blow out all vents and fans. I have seen acer laptops get too hot, easily, so you need to make sure it is dust free.
G'luck
Posted on Nov 11, 2008
Anonymous
  • 267 Answers
SOURCE: I have a Acer aspire 6930. Sometimes, my laptop
ok sounds like you unit is in very serious need of cleaning and maybe even some virus removal.
to scan and remove viruses ( click here ). install this to your computer and allow it to scan and remove any found threats.
also click start then run or command prompts .
type : cookies.
a page will pop up. you will need to delete everything in this except index. index is a system file and can not be deleted. close this window and empty recycle bin. now you will need to repeat this step but this time you will type in : temp
delete everything in this window. these are the things that will slow your computer down. you will also need to do a disk clean up. and a disk defrag.
after that you computer will be running faster.
also i subjest removing some things from your start up menu. this will slow the computer down from shutting down quickly.
i hope this was helpful.
Posted on Nov 13, 2009
Testimonial: "Thank you so much! But when I do the comman prompt, and type in cookies and temp, nothing pops up!"
EMKartha
Murali Kartha
  • 163 Answers
SOURCE: computer freezes after about 5 minutes of turning
Looks like the Laptop is running some backend program which could be either a service, an application running at the stealth mode, or a driver program that seems to seize the Memmory resource allocated to the Kernal. Did you try check the system log by going to Start - Run - eventvwr.exe wherein you will find two heives namely Application and system. On the second start try to go through this event viewer which is opened as i said before and find out if you can locate any memmory related critical error or any application related critical error which lead it to a hung state and a restart registered later.
If you cant find that please boot in a safe mode and see if this is happening. It should not happen ideally speaking. Still if this is happening, try to restore the OS or run the repair disk of Acer Aspire. This should resolve the issue. Still if you cant resolve this issue its surely due to a hardware problem. I would advice you to go ahead tappering the chances of problems starting from an OS monitoring to Hardware Troubleshooting as per the steps i have explained here. Good Luck.
Posted on Feb 14, 2010
Anonymous
  • 132 Answers
SOURCE: Intermittantly the curser freezes then erratically
Make sure that you are not placing the hand on the touchpad while typing.... This might be due to the drivers issue with the touchpad.. Try to unistall the drivers of touchpad from the device manager.. Then install a fresh copy from the dell website(www.support.acer.com).. If the issue is yet to be fixed please contact Acer to replace the touchpad....
Posted on Sep 17, 2010
Why toshiba satellite pro C50-B series curser freeze
When the curser freezes, first press the windows button to see if the entire computer is frozen. The windows button is in the lower left of the keyboard near Crtl and Alt buttons. If the computer is still working, then i would start with the software that is running the mouse. I think Toshiba has their own proprietary software that runs their mouse pads. Try to update the software through Toshiba's website. If that does not work, i would try updating the driver for the mouse. If that does not work, you may want to contact Toshiba for more detailed assistance.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_76c7b1512fdc05a2
Screen Freeze
Overheating causes laptops to freeze. If you haven't been using a laptop cooler then start using one. Laptops need proper ventilation. If that is not the cause then you might need to re-format your system as there might be important extensions/files that were deleted accidentally or your system might have been invaded by viruses.
Acer 5542 freezes
You can start by checking the Event Viewer. Right click My Computer / Manage. Check System for Errors and Warnings. They can be very technical, but most likely there is some event. Check Application as well. There is a Filter option under View. Leave Warning and Error checked.
A helpful tip.
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
I have a acer notebook 5532-5535 my mouse curser is frozen in the middle of my screen i have tryed fn f7 and fn f6 niether is working to un freeze my touch please help me
reset by going to start and tiping in word mouse it will bring your mouse settings up and change settings from there you might have to restart system first so mouse will move.
2answers
My Acer aspire 6920 laptop keeps freezing . It will load up fine and then after about 5 or 10 minutes it freezes and says the programme is not repsonding. Noting will work i.e. the mouse won't move,...
HI, what program is show this message? is it always the same program? if so try uninstalling that program and reboot the laptop to see if it will freeze up.
1helpful
After about 5-8 minutes everything freezes, mouse, can't even use ctrl,alt delete, what to do? Do I have a virus?
Are you using vista? If so beware MS updates. Also keep a close eye on the temp. of your laptop. That model Acer aspire 5520, is known to have an overheating problem and /or cold solder joints on the motherboard under cpu block and the video chip. I can't say if you do or don't have a virus, but if when you turn on, and the laptop starts cycling thru on, then off non stop, you will need to research reflowing solder with that model. I have repaired 2 units with that issue.Run malware bytes antimalware, SuperAntiSpyware and Spybot S & D and see what they say.
1helpful
4answers
My mouse freeze?
try control alt delte > users > (choose your user) > then log off > log back on. Did it work? I hope so! :)
How can i keep my cursor/ponter from feezing my cursor for my laptop keeps freezing up and i have to keep restarting my computer to get it undone
If it does press control,alt, and delete witch will u freeze it and bring it to the center of the screen. There is really no way to prevent your curser from freezing.
System boots to the paasword area then the keyboard and curser freezes up can not put in password.
Sounds like a mouse driver error. Try unplugging the mouse and booting with only the keyboard connected. Once you've typed in your password and logged-in you will need to 1) delete the existing mouse driver and 2) plug your mouse in and let Windows discover the new hardware. Use the recommended driver and reboot your system after it's finished installing.
Good Luck!
2answers
Screen freeze
Try go to safe mode. press f5 during boot (for xp) and f8 for vista.
Computers & Internet Logo
Ekse
Steve Sweetleaf
Steve Sweetleaf
