Question about Dryers
I have a Hawiian Breeze floor stand fan. It turn on it turn but the blades do not turn. can someone please help? I ned to know what is wrong with it and were I can get the parts from.
The Hawaiin Breeze is Model: FS40-12R Input 120v 60hz 0.55A Conforms to UL Std. 507 Intertek 3068797 If possible can you provide a phone number of the company. Thank you
Posted by Leticia Ponce on
Jasen Hinds
    New Friend:
    Problem Solver:
  • 15 Answers
How old is it????
Posted on Jun 05, 2015
Where can i get motor for Aloha Breeze Floor Fan Model 12001
online search or hvac / parts stores like granger , etc ==take the nombers off motor the get a match
Jul 08, 2017 | Dryers
How do I clean the Hawiian Breeze Fan
with a damp rag if it is a cieling fan. if other type, you can easily take them apart for yearly cleaning, and oiling
Sep 13, 2012 | Hunter 25517 Summer Breeze Summer Breeze...
My blade on my stand fan was put on wrong and is now stuck
take the "blade" back off and turn it around. It comes off easily with a stsndard thread knob at the center of the blade. hope this helps
Sep 13, 2012 | Windchaser (WC163C) Stand (Pedestal) Fan
Have an expensive Hunter indoor/outdoor pedestal Fan that stopped working. It just "hums" and does not turn. Please help.
With the fan UNPLUGGED, try to spin the fan blade with a pencil or something that will fit through the blade cage.
If the blade spins easily, there is an electronic problem (control or motor) that must be serviced.
If the fan blade is stuck or very hard to move, the shaft and bearing are probably dirty and need to be cleaned. You can temporarily fix this with a tiny amount (a drop) of WD-40 applied to the shaft where it enters the motor. Spin the blade manually to work the oil into the bearing. If the motor spins freely, the dirty bearing condition is verified. To properly clean the shaft and bearings, the motor must be disassembled.
Jun 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
The remote control for the Hawiian Breeze Tower Fan is missing. Can I purchase a new remote control?
If the remote control is missing you have an option to purchase a new one. Just to make sure it is compatible you may purchase it with Hawaiin aloha breeze provider. You may contact their CS number at 800295-4448
Mar 12, 2011 | Tower Aloha Breeze Fan
I need a fan blade for a Aloha Breeze floor fan
check the big box stores for replacement blades.
Sep 28, 2009 | Dryers
Broken threaded plastic part to hold blade tight.Aloha Breeze Vintage Stand Fan Model 46051
Have you tried using the Evostik Superglue for Hard Plastics
It is brilliant for putting broken palstics back together again
May 25, 2009 | Tower Aloha Breeze Fan
Nautilus bathroom fan blades don't turn
The motor is sized up. call someone to replace it and they should know how to remove the cover.
Nov 01, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dryers Logo
142 people viewed this question
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
