My subwoofer had no sound or power. I replaced the ZN3 diode and now I have power but still no sound. Any suggestions?
Posted by Chris on
Steve K
    Genius:
  • 1,054 Answers
If this is a boston acoustics sub, then I assume you replaced ZD3. You also need to check R9 on the back of the board. It is a surface mount resistor and should read 10 ohms. This resistor sometimes goes open when the diode shorts.
Posted on Jun 09, 2015
Testimonial: "I checked R9 and it reads 11 ohms so I am assuming it is fine. I did replace ZD3 which restored power but still no sound."
  • 2 more comments
  • Chris
    Chris Jun 09, 2015
  • Steve K Jun 10, 2015
    Look at C18 & C27. If they have any signs of venting (usually shows as what looks like putty bubbling out of the body) they need to be replaced. that's the only other commmon problem I've found with these subs
  • Chris
    Chris Jun 10, 2015
    ok. I will check. Are those capacitors? If they are bad would you know the specs them?
    they are .1uf/250v caps
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
Unit does not have power
check the fuses in the fuse box there may be a blown one, Look in your owner's manual or the display on the fuse panel. good luck
Apr 07, 2013 | Spherex Xbox 5.1 Surround Sound System...
Mcs 160 subwoofer no power
I had the same problem with my subwoofer unit. I found the zener diode ZD3 was fried. The pic below shows the diode and its clearly tagged ZD3. You need a multimeter to check this before you order anything. This diode should only transmit power in one direction. Its size and spec is 18v .5w zener diode. (that's 1/2 w) It's very inexpensive and the whole repair took about an hour. This is from a Boston Acoustics subwoofer MCS 160
Ok..the procedure is easy.
1) unplug the unit and bring it to a well lit work area.
2) remove the panel from the back and locate the board that is held to the panel by 4 screws and has the ZD3 diode. The pic below shows the diode at the end of my test lead. Note the direction of this part and reinstall the new one in the same direction. Its a simple de-solder and re-solder project. I elevated the new diode about 1/8 " from the board with a small strip of copper. This acted as a heat sink during the soldering and elevated the part above the board to help it dissipate heat later when in use.
3) re-install the board and plug in all the connections.
4) this worked for me and I'm enjoying my sound system again!..good luck0482b949-8492-43a6-91df-0fb2f0e6888b.jpg
Jul 24, 2012 | Denon Audio Players & Recorders
MCS 95 SUBWOOFER WON'T POWER ON..REPLACED FUSE WHAT ELSE TO TRY
Concerning the Boston Suwoofer not powering up, I just had the same problem and this is what I did to fix it.
1. Uplug the unit
2. Remove the outer screws and remove the board unit
3. Unplug the board (Power Board) that is connected to the switch and unplug the two connectors that connect to the amp.
4. Remove the 4 screws(on the front panel side not the nuts on the board)
5. Look at the switching diode (labeled #1) directly beside the transistor cooling plate, if the board around this transistor is burnt there is a good chance that the diode is fried. If you do not trust your eye you can measure across the positive and negitave of the diode with your multi-meter (on the diode check setting) and you should read ~.565 and you should read infinity if you swap the leads. If the diode reads ~.667 and you can read this taken across any polarity the switching diode is fried.
6. If the diode is fried go to radio shack
7. Purchase a 1N914-1N4148 Switching Diode. Cost about $1.36.
8. Go home de-solder the fried diode.
9. Solder in the new Diode. ***Pay ATTENTION to put the new diode in the exact way the old one came out!!*** If you do not get the polarity correct the diode will not work properly and your unit will not power up. Also, it is a good idea to leave ~ 1/8" between the diode and the board, this will help disipate heat the cause of the problem to begin with.
10. Place power Board back on the backside of the front panel
11. Install 4 screws(on the front panel side not the nuts on the board)
12. Plug the board (Power Board) that is connected to the switch and plug the two connectors that connect to the amp.
13. Place the panel back onto the subwoofer and secure it with the screws. You can use a screw gun for this just make sure to turn you tourqe level back to ~3 otherwise you could strip out the screw and or the particle board.
14. Plug it in and your rolling.
I hope I am not to late and this works out for you. I just fixed mine tonight.
Nov 01, 2011 | Audio Players & Recorders
Red light and thumping sound, same as earlier report on a infinity tss 450
If your talking about the thump thump sound thru the sub when in standby mode, here's a fix if your good with a small soldering iron. Remove the amp from the sub. Locate U301 on the limit curcuit. (the small circuit card standing up right) Replace U301 with a TL074IN (www.alliedelec.com part #248-0012) .35cents +S/H also remove R263 from the preamp board,add a new 1N4148 diode(#935-0242) .05 cents to the pre amp board. Connect the Anode of the new diode to the Anode of D101 and the Cathode of the new diode to the Cathode of D108. Replace amp and test. Thump thump should be gone.
Oct 30, 2010 | Infinity TSS-450 System
Hello I have a subwoofer and the fuse blew out. I replaced it with the same kind, but its still not working. The power light is on. When I turn it on it doesn't make that first thump sound. is it fixable?
It is very much fixable. Check if the fuse has blown again. And if it has, there is some problem with the circuit. Check conitunity across the main filter capacitor. If it's short, disconnect amplifier IC's power lines and check across the pins if it's short. In case it's short, you will need to replace the IC. But before replacing check all the rectifier diodes.
Dec 23, 2009 | Polk Audio PSW12 Subwoofer
My subwoofer IC got burned because i accidentally plug it to a 220v power supply, mine is only 110v i want to know the IC# subwoofer.
Most likely what got burnt is the bridge rectifier in the power supply section of the electronic circuit. This usually takes the shape of either a single 4-legged IC, or a group of 4 rectifying diodes connected in a bridge configuration. If you disassemble the unit to which the power cord is attached & trace the circuit starting from the terminals of the power chord, you can easily identify it. You will need to replace the 4-legged IC or the 4 rectifying diodes.
You will also need to replace the fuse, since it is usually likely that it gets burnt if the unit is attached to 220V instead of 110V.
Nov 24, 2009 | Altec Lansing FX4021 Computer Speakers
Speaker cable installation
1.  Check the orange multipin connector for bent or broken pins.
2.  Make you have the subwoofer plugged in to a live power outlet.
3.  Check the fuse on the circuit board inside the subwoofer.
4.  Measure the output of the subwoofer power transformer.  I think I remember it as being in the range of 12-24VAC.  Inspect the rectifier diodes for signs of overload.  measure the dc output of the diodes.  I think I remember 18VDC.
5.  Open the right speaker and verify the on/off switch is working.
6.  New Egg sells a multitude of similar speakers in the $40 to $80 range.
Apr 04, 2009 | Dell HK395 Computer Speakers
632 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
