Question about Champion 3500/4000 Watt Portable Generator
Do you adj. the valves on a champion 4000 generator hot or cold
Posted by Bob Rowland on
Thomas Smithbrother
    Top Expert:
  • 3,698 Answers
Www.championpowerequipment.com/
Adjusting valves on any warm engine is wiser . Specifications are usually listed for both.
Posted on Jun 05, 2015
I need a repair manual for my champion generator
You can't download the manual free, you must purchase it thru the manufacturers parts division.
Oct 19, 2016 | Watts Electrical Supplies
Why does it use so much oil, have to add oil every couple of hours
Hi, I believe the motor needs a ring job. You will have to disassemble and get new rings on the piston. Also look at valves guides they will need replacing. In short , you'll have to get a new motor.
Hope that helps.
Oct 20, 2015 | Champion 3500/4000 Watt Portable Generator
My Champion 4000 watt generator will not start in cold weather
If you want it to start with a start motor, driven from a battery, my guess is the battery is in bad condition. Normally a battery will perform less when temperature is going down, but an old or worn out battery can't perform at all when it is cold. I would check that first. Just take a good battery to start one of them and see what happens. Then see if you want to replace them.
Nov 22, 2014 | Champion 3500/4000 Watt Portable Generator
My generator runs at too high a speed
screw anticlock wise speed regulater on the carborator
May 10, 2014 | Champion 3500/4000 Watt Portable Generator
Champion 3500 generator how to fix stuck float
It could be a carburetor problem or it may be the low oil cut off switch. Check to make sure oil level is up. If it is check the needle valve attached to the float and the seat. The old carbs used to have a brass seat. Some of the new carbs have a rubber seat and it may need to be replaced. Hope this helps.
Dec 31, 2013 | Champion 3500/4000 Watt Portable Generator
Oil is being pulled from valve cover to air filter on my onan microquiet 4000 generator, what do I need to do?
63525c2e-e749-4a53-8402-d0463bb6c753.jpgThat sounds like the reed valve sticking or dirty.
You will need to take out the reed valve, clean and re-install. Be aware that a small amount of oil is common, also do not over fill the oil. The full mark is hot. Too much oil in the crakcase can build up pressure and keep the reed valve open.
Aug 22, 2012 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Aug 02, 2012 | Champion 3500/4000 Watt Portable Generator
Champion 3500/4000 Watt Portable Generator Logo
624 people viewed this question
Top Champion Televison & Video Experts
Lee Hodgson
Lee Hodgson
Harrie
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
