Only in the play mode the camcorder begins to squeal or squeak immediately or after a short time and then switches off. Needs the camcorder some oil for the rolls which transport the tape?
The same problem exists in the camcorders from Sanyo VM-D8P and Siemens FA 129 G4 which have the same mechanic as the Sanyo VM-D6P. I bought them for having spare parts. But they are all old.
The loud, constant squeak/squeal from your Frigidaire dryer, combined with a burning smell, indicates a serious problem that needs to be addressed. While replacing the drum bearing kit was a good step, it appears that there may be other issues at play.
One possible cause of the squeaking could be a worn or damaged drive belt or idler pulley. If the idler pulley spring came off, it is possible that the belt is not properly tensioned and may be slipping or rubbing against the drum, causing the squeaking noise. Additionally, a slipping belt can generate a burning smell as it heats up from the friction.
Another possible cause of the burning smell could be a malfunctioning heating element, which may be overheating the dryer and causing the burning odor.
It is recommended that you stop using the dryer immediately and unplug it from the power source. It is not safe to continue using a dryer that is producing a burning smell.
unplug unit and check play in motor shaft. if it moves perpendicular to the bearing the motor needs to be replaced. There may be something loose causing a squeeking sound. you could check all the screws for tightness.
Immediate Service required. Check transmission oil. It's either wrong oil type or oil level is too low. Automatic transmission oil needs to be replaced every 60.000 km.
until then don't go too fast and accelerate moderately.
I had a book written for you and remembered something basic I learned in electronics school and had to delete it all. Sigh. So with a smile I start all over and hopefully make this short.
Are you certain there is a belt?
Let's assume there is. A belt means a motor is spinning the belt which is spinning another pulley or "wheel". You could be correct that the belt needs to be changed. They stretch over time causing slippage. That is one way you hear "squeak". The other way which I hate and am dealing with on my car right now is the pulley or pulley's themselves.
If you don't have a belt then your motor is directly running your fan. That means the "squeal" is coming from the pulley's bearings. Most fans I have seen come pre greased from the manufacturer and are not made with a hole to squirt a little inside. They are designed with an expected lifespan. That's another story though.
The bearings get too dry and they begin to, well, drag. That drag is the squeal you hear. Your warning sign that pretty soon they are going to stop dragging and just dry up and stop rolling completely. When that happens you may turn your fan on and hear a hum but the fan doesn't work. To simplify this for everyone, the ball bearings inside no longer roll so the fan no longer spins.
You may have a belt and two pulley's (or more like in a car) and have a good belt but a bad pulley. Most people throw away the product thinking it is no longer useable when all that is needed is to loosen a single screw in the middle of the pulley and replacing it with it's exact make giving the device another jillion years of use.
Now for the conclusion. If you find that the pulley is the problem, go ahead and change that belt that has never been changed to save yourself from the squeal you will hear from that new strong pulley making that loose belt squeal.
One last thing. Check by seeing if it wobbles when turned on or feels loose and slightly wobbly when turned by hand, with it turned off of course. Good luck.
usually when a treadmill begins to make a squeaking sound it means that the belt needs to be lubricated. Try Treadmill Belt Lubricant available at Canadian Tire for $10.99 and is good for Reebok treadmills.
Hi, Initially I had the same problem with the finalization process. But then i took off the battery pack and connected to the mains and immediately when i switched on the camcorder again, the ' Finalize ' button was highlighted i.e enabled. I continued with the finalization process and everything was fine. Was able to playback the mini dvd on a very cheap dvd player and also on a computer.
Also be sure to put the camcorder on play mode by sliding down the switch button to mode. You immediately notice that a little green button near play will light up
The pump motor is beginning to seize up. You may be able to take the dishwasher apart and lubricate the bearings and keep it going for a while, but at some point you will likely have to replace the pump motor assembly.
* The MPEG Playback function works in M. PLAY mode only.
* You can play moving picture images on the Memory Card.
* To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV)
1. Set the mode switch to MEMORY CARD position.
2. Set the power switch to PLAYER mode.
3. Press the MENU button and turn the MENU DIAL to highlight MEMORY.
4. Press the ENTER button to enter sub-menu.
5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT)
6. To exit the menu, push the MENU button.
7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback.
8. Press the PLAY/STILL button.
The moving pictures recorded on the MEMORY CARD begin playing back.
