Magenta Print head (print head has the LASER inside of it that writes the image on the drum) in this case it is the magenta LASER. Open and close the front door to reset. If it comes back replace the print head. Normal done as a set of all four. (Black, Magenta, Yellow, and Cyan). Worse case is the relay board is bad or the Image control Board$$$$$$$$$$$$$$$$.
Try this site as a start:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
When a printer error occurs, the Alarm lamp is lit orange. The number displayed on the LED indicates the type of error that has occurred. Check the error code displayed on the LED and take the appropriate action to correct the error.
E and number (error code) are alternately displayed on the LED of MP210 series.
Error E, 2:
Cause: The machine is out of paper. / Paper does not feed.
Solution: Reload the paper correctly and press the Black or Color button.
This sounds like to simple a solution. Make sure this is the correct error code and it is not followed by another number. If problem persists check that you have removed the protecftive material from the FINE cartridge holder. Unplug the machine from the power source for several minutes. Power up. Hopefully this corrects the problem.
If not, try checking the status of your ink cartridges:
1 Open the printer properties dialog box from Control Panel.
2 Click View Printer Status on the Maintenance sheet.
To confirm the FINE Cartridge information, click the Ink Details menu.
This my give further clues to any problem.
Trust this is helpful. :)
