Question about DISH Network Televison & Video
My system skips channels when changing - DISH Network Televison & Video
dish guy
    Scholar:
    New Friend:
  • DISH Network Expert
  • 82 Answers
To whom it may concern,
Press guide once, and it will open the guide. Press it again and it will begin alternating between different programs.
"My HD"
"My favorites"
"All Channels"
Keep pressing guide until it says "My channels", this will prevent you from seeing channels that you cannot view.
Best of luck
Dish guy
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brian_142c5ec89a7a3fda
Posted on Jul 23, 2016
Barry Barrett
    Scholar:
    New Friend:
  • 73 Answers
In your guide, in the top left hand side, it will show which favorites list you are in. My Channels is all the channels you are subscribed to, My HD Channels are all the HD channels you are subscribed to, All channels is every channel whether you subscribe to it or not, and then any of your own custom favorites lists. While these selections change what is in your guide, it also changes what is available when you flip channels without the guide. While viewing the guide onscreen, hit the guide button again and change which favorites list you are using to one you prefer.
After this, the only channels skipped will be ones that either don't exist, or are outside of your selected favorites list.
Posted on Jun 06, 2015
johnny rebel
    Top Expert:
  • DISH Network Master
  • 10,875 Answers
Call dish
Posted on Jun 04, 2015
What's the imput button or code on remote for ten year old TV. Model #14MS2331/17
According to the manual for the Magnavox 14MS2331/17B, you switch to the A/V input by pressing Ch+ or Ch- on either the TV or the remote until you see AV as the current option. (Thus you have to scroll down from Channel 2 or up from Channel 69 for an OTA signal. For cable TV, the AV will be reached by Ch - from channel 1 or Ch + from channel 125.) See page 3 (7 of the PDF) here: http://download.m4c.magnavox.com/files/1/14ms2331_17b/14ms2331_17b_dfu_aen.pdf .
Since it is possible to skip channels by editing the channel list, you may need to check if the AV option has been skipped. To do this, press Menu. Use the up/down buttons to navigate to Install and press the right button to enter this menu. Highlight the Channel Edit line and press the right button to check this. Once in this sub-menu, use the left/right buttons to scroll through the Channel number options (or use Ch+/Ch- to see the stored list). You can also type in a channel number on the remote. Press the down arrow to change to the line that reads Skipped. Use the left/right arrows to change between Yes or No. (No indicates you can reach the channel with the Ch+/Ch- buttons.) Use the Up arrow to return to the channel number line to scroll to other channels. Press Status/Exit to leave the menu system. See page 10 (14 of the PDF) for details.
I hope this helps.
Toshiba LCD TV/DVD 15LV505 lost channels. Rescan = fewer channels. Now in Setup, when I press the remote down-it skips the Channel option. What must I fix/change in Settings to get the Channel option?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Skip channel function not working coreectly
db:: 4.90::Fios tv VMS1100 skip not working correctly k3
www.hivmr.com/db/k37cmjfzkk71s913ksf3j7xfxsz3zc37
DB:4.90:Fios Tv Vms1100 Skip Not Working Correctly k3 ... Pressing Play on the remote has no effect, but changing the channel fixes everything. ..... The functions Skip Forward, Skip Backwards, Next Chapter and Previous Chapter all skip ...
The Secret Method to Skip Commercials with One Button on ...
Dewalt DSCN1360 tuner problem
Don't you have an automatic tuning system or ATS? By pressing a band switch for a while the ATS starts looking for stations and stores the ones that have a good enough signal. Even if a station broadcasts but the location of the radio is not adequate for a good signal to be received, the station won't register and it will appear to you that the tuner is skipping.
Auto Channel Search places all channels in skip mode causing channel changes to made by number input instead of up/down button. Having to manually turn "Skip" off on each channel individually.
check the agc line from the tuner is functioning properly, if the agc signal , is not reaching the processor it will register that channel as being inactive and lock it out, there is not much circuit to contend with so a multimeter should do the trick to trace down the fault, you should find AGC marked on the board where the tuner modual is mounted.. i suggest obtaining a service manual to do the job good luck
Skipping channels
try a reset on it. push and hold the power button down for 5 or 10 seconds untll it goes off. it will then "acquire" satellite and reload program info and then it should work right.
2answers
More channels
Go into the menu to the "Search" tab, channel down until you are on "auto search" then press "volume up"
this will automatically add channels you can get, you can manually change skip settings there too if you want to not see a channel you get or for some reason add a channel you don't get etc.
Televison & Video Logo
Top DISH Network Televison & Video Experts
Mike
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
