Apple Iphone A1387 Logo
vlad testiler Posted on Jun 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Attery not charging - Apple Iphone A1387
Steve L
Level 2:
New Friend:
  • Apple Expert 85 Answers
  • Posted on Jun 05, 2015
Steve L
Apple Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
72844
Points
157
Check the charging port and clean with an old toothbrush if found to be dirty.
Error code 3.5 on john deere 797 zero turn mower flashes. Pto cuts out. Any info on this problem?
I am not familiar with this model but know that you should check these items;1. Level of charge in battery. 2. Water level in battery. 3. Check for loose connections to battery and also electro magnetic clutch on drive pulley. Try putting charger from external power to attery for several hours. These clutches soak up the power and can let go if the battery is old or not charging properly.
Jul 21, 2014 • Garden
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
2helpful
Won't start ~ rode a few hours then parked it ~ turned on key no lights came on ~ i checked the starter connections ~ all fine there nothing ~ ran great before
there is a high possibility the battery is dead. or maybe the bike isnot charging the battery. i suggest push starting it then ride it a few blocks and shut it off pull the key and then start it again...it might be the attery wont hold a charge...if thats the case then replace it but do that before messing with the stator. hope this helps good luck!
When started battery light stays on for god time befor it gos out b attery test ok
the battery light is actually the amp gauge.when the light is on it means the battery is not charging which is normal when starting.when the light goes out the stator is charging the battery.
Dec 21, 2010 • Garden
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
