Question about GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator
Water is not coming out from GE Profile PFSS6PKW, how can I fix this?
I thought it is the water filter, but I put a new GE water filter and hit RESET FILTER, still no water coming out.
Posted by Alfred of Maryland on
guy dubeau
    Sergeant:
  • 306 Answers
Check water line is not kinked
Posted on Jun 04, 2015
Testimonial: "What do you mean by "water line is KINKED"? And where is the water line? Thanks for the answers."
  • guy dubeau Jun 04, 2015
    the water line from the house to the fridge when you pushed the fridge back in place you may have pinched the water feed
  • Alfred of Maryland
    Alfred of Maryland Jun 04, 2015
    I never move the fridge since it was put there. The water line should not be pinched. There is water filled in the new filter when I replaced it. Another other suggestion?
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
Filter light will not turn off
Resetting your Refrigerator filter indicator light after changing your water filter
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Nov 11, 2012 | GE PFSS9PKy Refrirator
I replaced my GE profile MWF water filter (identical GE part) and now I dont have water dispensing and don't have a working ice maker
Quite frequently carbon fines can be flushed from filter and plug the filter. If you have the bypass plug to replace the filter. Put that in and flush system completely. Take the filter and flush it at the kitchen sink. It is best to fill these with water before installing and flush the carbon fines before installing in fridge.
RJ
Mar 09, 2011 | GE Mwf Ge Refrigerator Smart Water Filter...
Water flow is extremely slow after filter change.
Those filters are for refrigerators that have heavily treated water in the household. You could have a filter that filters your water supply and not use the filter inside the frig. Why use both? Now, if your home is not filtered, you may need it. Check to see if the water supply line is crimped somewhere or frozen when it gets inside the frig.
Jul 15, 2010 | GE Refrigerators
I just installed a new MSWF water filter cartridge on my GE Profile refrigerator. After pushing the reset button, there is no water flow at all. I can hear the pump humming. I tried removing and...
Tried new filter. Thought water line frozen. Problem solved by bypassing the water filter. Now that I'm working without filter I will troubleshoot the filter receptacle.
May 04, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
No flow after filter change.
G E waterfilters , can be bad when new (all , not just G E ). Put your old one back in , if water flow was fine , and you replaced just because the light came on . Or , use the plastic bypass piece , which came with the refrig , when new . The replace light , works off time and/or usage times only . If you have good water flow and the cubes are normal size , don't change the filter when the light comes on , just reset the light . All "filter" companies , have found the way to sell more filters , the light on dispensors .
Sep 11, 2009 | GE Refrigerators
HAVE REPLACE THE FILTER, NO WATER OR ICE WHEN FILTER WAS OUT MADE ONE BATCH OF ICE THEN STOPPED NO NOTHING WATER IS ON NO KINKS IN HOSE WHAT IS WRONG THANKS ROSE
Try putting the old filter back in . Just because the " change filter " light comes on , does not mean to actually change the filter if your water dispensor is not just trickling out . If water was coming out fine before replacing filter , no need to replace it just because ot the indicator . I have found new filters which worked worse than the old filter . Just put the old filter back in and problem solved .
Jul 18, 2009 | GE Profile PSI23NCR Side by Side...
Water coming from the dispenser is very slow
hello from fixya,most important is the supply shut off the water undo where conects to the refer.put inside a bucket/pot and turn on water you should have a great flow.if ok there you could move to filter but the water valve could have a mineral blockage and is harder to test.you would have to undo the out put side of the chilled water then hit the water cradle.etc.. on the ice maker.also a thought.if ice small and water slow.may be filter if had good house supply.hope that helps.God blessyou house,tom
Jan 02, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE PROFILE PSS26msrd Ice maker not working water dispensor ok new water valve new filter fill tube seems clear Does anybody have any sugestions before i replace the ice maker unit?
water does become ice inside the pipe in side the freezer it happens to my frige at list once a year, put a hard wire or pencil up to make sure that is not the problem, before you spend any more money
Dec 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator Logo
289 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
