Dyson AM04 Hot Cool Heater/Table Fan - Silver Logo
Question about Dyson AM04 Hot Cool Heater/Table Fan - Silver
What does e8 mean on the display?
I bought the fan few days ago , when the weather became colder tried to open up a heater, but it gave e8 code and stopped with blinking red power light.What should i do?
Posted by Nigan Ozkan on
AskDyson
  • Official Brand Answer
  • 2,572 Answers
Hi Nigan, it's Jack at Dyson.
If your Dyson Hot + Cool fan heater is displaying an E8 error code, you may need to reset your machine. To do this, just switch off and unplug your machine from the outlet for at least 30 seconds. Once you've done this, plug the machine back in and test it - the error code should have cleared.
If you're unable to reset your machine, please contact the Dyson Customer Helpline directly so we can provide further assistance. If a repair or a replacement part is needed, we can confirm if this is covered under your Dyson warranty. When you have your machine easily to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on Jun 04, 2015
Huseyin Huseyin
  • 3,469 Answers
Http://www.dyson.co.uk/support/am04/am04-irsbl/my-machine-is-not-working/e1-e5-e6-am04
Posted on Jun 03, 2015
1helpful
Hi. I have a Dyson AM05 fan heater purchased July 2014. Whilst the cold air works brilliantly the hot air doesn't work at all. It shows an error message E8. Any advice?
I suspect that the microprocessor detected an overheat fault and is keeping it in E8 mode to prevent fire. The code needs to be cleared somehow. If it has some buttons on the front then try holding one whilst plugging it in. This may reset it. The reset will be something along those lines. Don't open it because if you can't fix it that way you need to take it back to the shop.
Erroe message e8 showimng
Hi there, it's Jack at Dyson.
I'm sorry to hear your AM04 is displaying an error code. When you have your machine to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We can take you through some simple troubleshooting checks, and if a repair or replacement is needed, we can confirm if this is covered under our 2-year warranty.
We'll look forward to speaking with you.
Defrost timer on TFX27PF
HI SCOTT.a bit vague but i'll assume u mean it blinks but it cools for 4 days and then starts defrosting right?(temp drops u mean it gets warmer NOT colder.) well first i would check your condensing uni thoroughly.check if evaporator is iced up or not.ventilation ok.if iced up defrost all 24/48 hours and try .u could get lucky.if same again check heater and t/stat and defrost timer.if not iced up check refrigerant. fan motors. and compressor.good luck ali
8helpful
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Vegetable draw is getting too cold and freezing contents,
Good day,
Seems to be a common complaint when colder weather sets in.
This problem seems more acute when the rooms cool down, and the machine gets light usage.
The main reason, is the machine stays off for longer periods of time and the air stratifies in the fresh food compartment.
That is, the cold air tends to settle to the bottom of the compartment when the machine is off and the circulating fan is not running.
recommendations are to set the thermostat to a warmer setting..
Sounds good, however, there are techs who recommend setting it to a colder setting, to keep the fan running more frequently.
I know it sounds ludicrous, but it's primarily the result of trying to keep one compartment at 0 degrees and another at 37 degrees using only one compressor and one cooling fan.
Many years ago, many refrigerators had 2 fan motors, one for each compartment, and 2 thermostats. These machines never had this problem.
Frig too warm, freezer too cold
if there is ice build up you have a defrost problem. either the heater bimetal thermostat timer or evap fan could be bad. you could also have a stopped up drain. if the coils get too much ice build up the air wont beable to travel through them and the bad air flow will cause the fridge to become warmer
CPU fan died again
what's the output at the mobo connector?
2answers
Heater is getting power, but will not work
I guess of heater element are open and this can cause the fan from not working because both of them are on the same wiring
Top Dyson Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
Are you a Dyson Heating and Cooling Expert? Answer questions, earn points and help others
