HP PL4260N 42 in. Plasma HDTV Logo
R
Reta Williams Posted on Jun 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Could my picture tube be out ?
No picture or sound will not come on could it be the picture tube.
johnny rebel
Level 3:
Top Expert:
  • HP Master 10,875 Answers
  • Posted on Jun 03, 2015
 johnny rebel
HP Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2939515
Points
47944
Plasmas dont have tubes,there are 3 computer boards inside that can go bad,power,control and backlight,contact the company for service
Sound ok but no picture
Check the high voltage on the picture tube it should be around 26 thousand volts. Check the back of the picture tube to see if its lit.
Rich
Toshiba model CF30D50 has sound and will change channels, but picture is dark, can see vedio 1 and 2 faintly, but can get no picture on TV channels
Its a older set with 3 picture tubes---when was the last time the mirror and three lens for the tubes were cleaned?
Has no picture but has sound
I understood your problem there is fault in to your picture tube or it may in supply given to GRID of picture tube because only sound section is working so only sound comes out but not the picture, or also checkout the DEFLECTION IC(both horizontal & vertical deflection IC)
Thank you to give me the chance to help you.
give your ratings please!
No picture the picture worked 4 hrs ago great sound now we ahve sound but no picture
try to check the supply of the heater from the picture tube..check for open resistors..the heater is located at the CRT board it is the board that connected to the picture tube the supply of the heater comes from the plyback...
Picture is a blue screen but the cable and sound still works. The picture briefly appears when we turn on the tv then it fades to blue. Its a Prima tube tv.
It sounds like the picture tube is shorting at the blue gun. Most of the time it is not cost effective to replace the tube. Have a repair shop check it out and see if that is the problem. Thanks
2answers
No picture displayed when switched on
picture tube problem.......change it!!!!
Sound but no picture is it the picture tube or just another problem
most likely will not be the tubes mate, if the tubes go then you just get a big mix of red green and blue colours in the screen - sound but no picture is more likely to be the starter unit on the flat screen.
flat screens have a starter unit - mine went on a samsung but under warrenty
Tv will not turn on, just makes a clicking sound
Brother this is problem usually  when either the fly-back (picture tube transformer )or tube  voltage regulator  Transistor is damaged or the picture tube has a short
Best of luck
Is this fixable??
Unfortunately, this sounds familiar. Many of these sony projections had bad crt's.(picture tubes). Now here is a secret I learned along the way. The short in the picture tubes is in the filament, causing that color to overpower all others and sometimes causing pix to disappear until set is shut off and back on. If you are very careful and use an insulated screwdriver, you can sometimes tap on neck of picture tube and knock debris from filament causing extended tube life. This is dangerous and must be performed with set turned on. From front of set gently tap on neck of tube(s) in question using insulated handle of screwdriver to make contact with picture tube neck. Picture will probably flash whichever color tube is contacted. Eventually, if picture stops flashing that color as much, you can sometimes get several more months out of your set without any problems. Only alternative is to try a crt rejuvinator or replace tubes at a cost of 200.00 each if avail. plus labor. Good luck, Russmann.
PICTURE TUBE
32 inch Albatran Monivision Moniter, when plugging the VGA in the tower thers no picture. the moniter comes on saying " No Signal No AV Box Action
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
