Question about Husqvarna Garden
How to replace steering rod on a Husqvarna Lawn Tractor Model YTH2348
Model YTH2348 Steering rod removal
Posted by Donna Mullins on
Timllfixit
  • Husqvarna Master
  • 2,210 Answers
Get a good DIY neighbour with a bag of tools to have a look. If not then see your local garden machinery shop.
Posted on Jun 02, 2015
I have a Husqvarna yth2348 that won't turn. requesting troubleshooting tips
Make sure the front spindles are greased and move freely. The other areas to check are the sector gear and pinion on the steering column.
Feb 21, 2016 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
What causes the front wheels to spread out making turning and steering impossible on a husqvarna lawn tractor.
the tie rod between the two wheels has broken or come off
the steering rod works on that rod or on one wheel which is connected to the other wheel by that tie rod.
Sep 04, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do I remove the steering wheel?
Remove cap on steering wheel, then remove nut.
Apr 28, 2014 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
My husquarna 2348 keep get slow forward and backup put new belt on it
I have found this on many husqvarnas around this model. A grass build up between the chassis and the second skin above the steering quadrant. lower the cutter deck, get on your knees on the left side of mower and reach up behind and into the back of where the clutch shaft goes into the chassis. The cavity is about 1 1/2 " high. Remove all packed grass.
Jan 30, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
RE: YTH 1946 The gear on the bottom end of the steering shaft is badly worn and steering is difficult. Where can I order a replacement?
try sullivans garden machinery they should be able to source these parts for you. Their contact info can be found on their website http://www.sullivansgardenmachinery.co.uk
Sep 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Gth2548 belt diagram and steering trouble
Go to searsparts.com type in your model number it should show your diagrams and parts for your mower
May 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
338 people viewed this question
Top Husqvarna Garden Experts
bryan st
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
