Question about N'FINITY Dual Zone Glass Door Right Hinge Wine Cellar Capacity: 166 Bottles"
Why doesn't my wine cooler cool? - N'FINITY Dual Zone Glass Door Right Hinge Wine Cellar Capacity: 166 Bottles"
Posted by Veronique Lawson on
On-Time Appliance
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
Could be a freon Issue. Check out or video. Hope it helps
Danby Wine Cooler Repair Recharging your wine Cooler with 134a Freon
Posted on Jun 03, 2015
Wine cooler not cooling.
Your themostat inside the cooler may be broken.
Mar 19, 2014 | EdgeStar TWR282S Wine Cooler
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
What is the best wine cooler in the market?
The NewAir AW-210ED is by far the most successful wine cooler there is making the best wine cooler overall for the price. The only downfall is that this specific model doesn't have the highest capacity for the price.
Aug 14, 2012 | Furniture
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
It just stopt cooling ([email protected])
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Haier wine cooler won't cool
Does the unit cool at all? If it is running and not cooling properly, check and clean the condenser coils on the back of the cooler.
Jan 25, 2011 | Haier BC112G Wine Cooler
Vinotemp VT-16TEDS has light on but doesn't cool
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Dec 31, 2007 | Avanti EWC28 Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
N'FINITY Dual Zone Glass Door Right Hinge Wine Cellar Capacity: 166 Bottles" Logo
1,086 people viewed this question
Top N'FINITY Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
Are you a N'FINITY Refrigerator Expert? Answer questions, earn points and help others
