Question about Denon AVR-1513
Is there a general issue with video and sound cutting/jumping out with more volume applied?
All HDMI, multiple sources used, higher the sound the worst the sissue occurs. Anyone?
Posted by Broman on
    Top Expert:
  • Denon Master
  • 76,466 Answers
Power supply section circuit problem. Check all the voltages and filter capacitors at this section. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Jun 02, 2015
How do I change the resolution on my Phillips 4k tv from 720 to a higher resolution tools
The TV will select the correct/appropriate resolution based on the source. To achieve the highest resolution you will have to connect a unit (video source) capable of providing 4K using HDMI 2.0 compliant cables. To achieve any HD resolution, the video source will have to be connected to a HDMI port. The ATSC terrestrial digital broadcast signal (over the air TV) is generally 720p, but many stations transmit in 1080i/1080p.
Jun 23, 2016 | Televison & Video
Why does sound turn off.
Follow these steps to troubleshoot if there is no sound or intermittent sound from the speakers.
IMPORTANT: Not all of these features and/or functions are available on all products. Consult the instruction manual that came supplied with your unit to verify if your particular unit has these features, or if more detailed information is required to perform any of the steps below.
NOTES: Click on the appropriate link below if the issue is occurring with a particular device or connection.
  1. Make sure the MUTE function has not been activated.
  2. Try turning up the volume level.
  3. Check that there are no headphones connected.
  4. Try setting the Audio/Video (A/V) receiver to a different Surround Sound mode.IMPORTANT: Verify that the source you are playing is encoded with Surround Sound audio. If not, the audio will be very difficult to hear using a Surround Sound setting. Set Surround Sound to OFF when playing a source that is not encoded with a Surround Sound signal.
  5. Check each speaker to make sure they are properly connected to the A/V receiver.
  6. Perform a Test Tone function to verify if the speakers are working correctly.
  7. Verify all external audio sources are securely connected to the appropriate inputs on the A/V receiver. NOTE: If the audio is being sent from a television to the A/V receiver, then it may be necessary to disable the internal speakers of the TV or set the audio output of the TV to FIXED or VARIABLE. If the audio output of the TV is set to VARIABLE, then you will need to increase the volume level of the TV.
  8. Make sure the correct audio input is selected on the A/V receiver.
  9. Confirm what type of HDMI® devices are connected to the A/V receiver and then check the following:
    1. Test each one of the HDMI inputs on the A/V receiver to confirm that all of the inputs for the A/V receiver are working.
    2. Try a couple of different HDMI cables to verify there is not a bad set of cables.
    3. Unplug the video source from the A/V receiver and connect the source directly to the television. If there is still a problem with the audio, continue to the next step. If connecting the source to the TV corrects the sound issue, service will be needed on the A/V receiver. NOTE: Additional troubleshooting steps are available to troubleshoot instances when the audio, video, or both goes out when using an HDMI connection.
  10. Verify the DEMO (demonstration) mode is not active.
  11. Change the ATT (attenuate) setting. NOTE: The procedure to change the ATT feature varies by model.
  12. Reset the A/V receiver back to factory specifications.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
Feb 04, 2016 | Sony BRAVIA Televison & Video
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Jan 06, 2016 | Audio Players & Recorders
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
My emerson tv say device control inactive
John, I've ran into this issue a couple of times myself. In most cases, there are easy fixes to the issue. #1, Does your TV have multiple HDMI inputs? They may be labeled HDMI1, or HDMI2, etc. I know this sounds strange, but many people don't realize that the signal source is important. #2, Connect the cord, from another device that you know works(laptop-monitor) to eliminate the possibility that your HDMI cord is bad. #3, (Probably most common) The PS3 is not the most stable platform when using the HDMI cord. Remember that the PS3 was one of the "pioneering" platforms using the HDMI connection.As such, the "auto-detect" feature is sometimes confused when switching between RCA inputs, and HDMI input. (Happens every time actually) To fix this, try a video reset on your PS3 system. It's fast, easy, and doesn't effect anything except the video/audio settings. I'll put in a link to get you started in that direction. It is the same with all models of PS3. Good luck! ^^
How To Reset PS3 Video Settings PS3
May 06, 2013 | Sony Playstation 3 (PS3) Console
Problem with HD channels on Elent 40" LCD HD TV
Could be the HDMI bank, try the DVI hook up, you won't have HD but it would give you knowledge.
Apr 25, 2017 | Element Electronics 40 in. LED HDTV
Just bought a Yamaha RX-V371 surround sound receiver and the TV audio signal is cutting out. I am running a Samsung LED TV with a single HDMI cable (sound/picture). I tested a smaller tv with a short HDM...
Settings are not the source of intermittent problems.
"Signal loss" is indicated WHERE? So what's going on upstream at the source? ITS cables are a part of this.
My $.02... I never route any signal unnecessarily to or through a device that doesn't enhance or consume it. Hence, my BEST video from each of my several video sources goes directly to my TV/monitor and my BEST digital audio from all sources goes directly to my AVR.
No problems.
Sep 20, 2011 | Audio Players & Recorders
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Sep 07, 2009 | Pioneer VSX-816-K/S Receiver
Sound cuts out when sound quality input changes on my rxv1700
Your HDMI version software and hardware will not work with todays version. The current version 1.3b is what works correctly (so far) IT can be upgraded to todays specs however, it's a preicey task for minimal gain if you are viewing any TV smaller than 50". The human eye cannot see the difference between 720p and 1080p on any TV 50 or smaller. That being said, if your TV has multiple HDMI ports, you can sidetrack this issue by connecting directly from the source, ie DVD, BLURAY, etc. then use optical or coaxial digital coaxial to the receiver. I know it's not the best news!! don't Blame Yamaha! it's been the recording industry and copyright protection issues that have overloaded product with "anti-piracy" software to the point you can't view it!. All receivers prior to 09' have multiple HDMI issues. Also, try setting your receiver to "Auto" in audio and running an analog RCA from the source to the receiver as well as HDMI, it may help, however, analog is much louder than digital, and I'm not sure if you can "offset" the volume level for analog in that receiver's settings. So, when you go to a commercial it could be unbearably more annoying than not listening to the commercial at all! Hope this helps.
Aug 15, 2009 | Audio Players & Recorders
Sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
Denon AVR-1513 Logo
90 people viewed this question
Top Denon Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
