SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
SOURCE: Are all bunker hill safe keys the same?
Never!.............sodeep (unless you happen to be the lucky one in a million)
SOURCE: Changing Combination of Bunker Hill digital floor safe
there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
SOURCE: I have a small bunker hill digital floor safe. I
follow the following link: http://www.harborfreight.com/manuals/91000-91999/91006.pdf you will see a picture of the bunkerhill digital floor safe, ITEM 91006-6VGA, under the sale price, you will see in GREEN "download product manual. There you will find the instructions for this safe. It took me about 30 minutes to find, then realized I didn't have batteries inside. Lucky for me, I found the key. You will need batteries inside. Otherwise, call the company Monday-Friday 9:00am - 7:30pm EST at 1-800-444-3353 (toll free). For Technical information call Monday-Friday 9:00am - 4:30pm EST at 1-888-299-3427.
SOURCE: bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
