Vtech 1930c handset display not working properly. It lights up but shows only random dots. Can this be repaired by opening up handset and disconnecting display and reinserting or resoldering?
There is a registration process you have to go through with each handset to connect the old handsets to the new base. It should explain it in the users manual for the base.
VTech Communications Inc.Out of range OR No power at base is shown in the handset display window. Why don't ... Tip 1 of 5. Confirm proper installation of the telephone base and charger power adapters, and handset battery. You should only use the VTech power adapters provided with your telephone. ... Next Tip This solved my problem. Tip 2 of 5.
VTech Communications Inc.Have a question about VTech cordless phones? Visit our ... How do I find my model number ... My battery pack does not last very long between charges.
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base. 2. Unplug power from the base. 3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key. 4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key. 5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE". 2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit. 3. Press "OK". The handset will display "PLEASE WAIT!!". 4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
has the secondary handset ever worked. Reason I ask is that it happened to me with a new addtl handset and the problem was that I did not remove the small piece of paper between the handset and the battery which caused only distorted figures to display on the LCD of the handset.
Tip 1 of 2
Recradle the handset for 15 seconds, then lift the handset and press PHONE.
Tip 2 of 2
If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
If that does not work, call the manufacture at
1-800-595-9511. Or take it back to where you purchased it and have then exchange it.
