Blackout tv screens
I am getting frequent tv picture blackouts with my Bell Expressu system. The backouts last only a few seconds, the picture goes black and the screen only shows my tv input selection(HDMI)
Posted by RFCLARKIE on
  • 3 more comments
  • tabumps Nov 30, 2007
    when the tv is in the hdmi 1 setting the tv goes blank for a second or two but the power does not go off, if i change the tv setting to tv so that the tv is not running hdmi this prolblem doesnt happen
  • jsbug May 25, 2008
    changed hdmi cable to see if the problem but not. frequent one second blackouts
  • gbraunst Nov 19, 2008
    Has anyone figured out the solution to this?  I have the same issue with my Sharp 52D62U.  Very frustrating.  It periodically, for no reason whatsoever, will go black for a few seconds, and the HDMI Input selector will appear at the top right before it comes back on.  I'm far from an expert on this matter...so any suggestions?
  • gbraunst Dec 11, 2008
    I have the same exact issue...Sharp LCD 52".  Purchased just this year.  It was working for several months, and then all of a sudden this problem started just a few months ago out of nowhere.  Sporadically the screen goes blank for 2-5 seconds, with the HDMI indicator showing on the top right.  There's no pattern or consistency as to when it will happen.  It's very frustrating!  Anyone have a resolution??
  • Linkage Dec 27, 2008
    Seeing the same problem with an LC-42D64U and the composite input... trying to find a solution...
2 Related Answers
Anonymous
  • 320 Answers
SOURCE: Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Posted on Nov 26, 2008
Anonymous
SOURCE: Screen blackout
I had the same problem and fixed it with a new backlight inverter board. It was a pretty easy install. The part is available on eBay. http://cgi.ebay.com/New-Inverter-for-Dell-W1700-17-inch-LCD-TV_W0QQitemZ400017456720QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Posted on Dec 26, 2008
My tv backout picture and sound remain audible, when i turn it off for a while it comes back on with picture and will remain on for a few seconds and then picture will blackout again. what do i need to...
You will most likely need to get the set diagnosed. Sounds like you have a backlight problem. Backlight problems could be cause by a fault in the power supply, main board, inverter board, bad CCFL lamp, or a short in a HV(high voltage) cables. I would say it's worth getting a proper diagnosis. However, if you choose to replace the set, you can get a pretty penny for it on Craigslist. If it is clean and come stand and remote, you could get as much as $100 to the right buyer!
Oct 29, 2012 | Samsung LN-T4042H 40 in. LCD HDTV
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen blackout
what is brand and model number? If had to turn on several times to get it on...........?
May 16, 2012 | Televison & Video
Sharp Aquos LC-C4654U The TV blacks out frequently. The blackouts last aprox. 1-2 sec and when the picture reappears, the blue box appears in the top right corner (just like when the tv is initially...
Good day!!! That problem is cause of faulty capacitors on the power supply... just look at the actual image of it through visual check if the capacitors look like leak/bulged on top you need to replace it to end that problem... hope it helps... \thanks for using fixya..
Sep 13, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
The screen turns blackout then after a seconds it turns back to normal..
The problem is the picture board on your monitor, the picture board on the monitor is malfunction, that is why the screen goes off after few seconds and turn back on.
If the problem is a regular one, i will advice you replace the picture board on your monitor to fix the problem.
Take care.
Jun 22, 2010 | AOC 5 En 15" CRT Monitor
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
When Blackout mode is turned on, the monitor display will turn off to
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Onida Ky Thunder tv blackout
my onida ky thunder giving fault led blinking after plugin and after 5 second goes to stopped mode
May 11, 2008 | Televison & Video
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
