Question about Apple iPhone 3G
How to use gps in iphone 3g apple - Apple iPhone 3G
Posted by shubhamjinda on
Anonymous
  • 31 Answers
Simply tap on "maps" on the homescreen to open the Maps application. Then tap on the little circle in the bottom left corner to locate yourself using the gps module.
Out of the box, the iphone 3g doesnt support turn-by-turn directions like your usual tomtom gps system.
You can download apps for that when youre on softwareversion 3.0.
Posted on Jul 13, 2009
5 Related Answers
Anonymous
  • 30 Answers
SOURCE: GPS not working
Try this -
1) Settings > Enable 3G Change to Off.
2) Use the iPhone GPS receiver to locate your position
3) Settings > Enable 3G change to On.
There are two positioning systems in the iPhone 3G, one is the 3G network, and the second is the GPS receiver. The problem occurs when the data from the two systems doesn't match.
Posted on Jul 31, 2008
Anonymous
  • 11 Answers
SOURCE: iPhone 3g White Apple Logo Screen of Death
Press and hold Sleep/Wake and Home until the iPhone resets.
When the Apple logo appears release Sleep/Wake, but do not release Home until you see the prompt to connect the iPhone to iTunes.
to restore the iPhone’s firmware, all your settings, all your media, and all your Apps.
I don't recommend you to do the offered backup, I've seen a few things more reliable then this backup, to say the least...
To avoid the screen of death, do not update all the features with the "Update All" feature, updates your features one at a time, avoid performing other tasks while updating your iPhone.
Posted on Aug 24, 2008
Anonymous
SOURCE: 3g iphone low volume, dropped calls, low bars when you just turn your head ,standing in the same place?
Mine drope the calls and the Apple Bluetooth hands free does not work in my 3G, the volume is very low, and with my old Iphone was great.
Posted on Sep 10, 2008
in9876388918
SANJEEV KUMAR SURI
  • 170 Answers
SOURCE: how to change the simcard of my apple 3g iphone?
The SIM card in the iPhone is removable, but it's hidden. To remove the SIM card, you need a paper clip.
We are checking to see if this voids your iPhone warranty. If you are concerned that it might, please don't perform this task.
The iPhone's SIM card is located behind this door.
1. Locate the SIM Card Slot
The slot is located at the top of the iPhone, between the headphone jack and the power button.
The paper clip is a valuable tech tool.
2. Open the Slot
Take your paper clip and insert it into the little hole. Then firmly push down until the slot pops up.
3. Remove the SIM Card
The SIM card is in a cradle. You can pop the card out of the cradle.
To replace the SIM card, put the card back in the cradle. The cradle and card are notched in a way that forces you to replace the card on the proper side. Then just slide the card back into the iPhone.
Thanks alot,
Sanjeev Kumar
Posted on Jan 22, 2009
Joed911
JDTec
  • 4338 Answers
SOURCE: Iphone 3g 3.0 stuck on iphone apple logo loading screen
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Aug 28, 2009
Testimonial: "the last option helped alot thanks x"
What is difference between iphone and iphone 3g
  • 3G speed capability
  • The iPhone 3G includes a built-in GPS.
  • The 3G is a bit thinner at the edges and includes a headphone jack that is flush to the side.
. The iPhone 3G differs from the iPhone in that it used 3G networking and included built-in GPS for expanded location based mobile services, and new iPhone 2.0 software
, which included support for hundreds of third-party applications that were built with the iPhone SDK
Jan 14, 2013 | Apple iPhone Smartphone
When using Navman in my vehicle on the iphone I have the iphone plugged into the vehicle phone charger. After about 50 minutes use runs the iphone battery completely flat and takes about 2 hours to...
that's because your using GPS signal that is constantly resetting itself and it uses battery life to do so, GPS uses more energy than anything else the iphone will do. If your still within hardware warranty call Apple and they might help you with it
Dec 21, 2010 | Apple iPhone 3G
My new iphone 3G wont pair with Tom Tom 520 - the tom tom finds the iphone, the iphone seems to find the tom tom, but iphone will not make full connection Any ideas please
i dont think the iphone will pair with the tom tom gps, because they use a different satellite & interface....iphone is running on Google whereas tom tom has its own satellite.
Mar 10, 2010 | Apple iPhone 3G
Sometimes the GPS of my iPhone doesn't work. Can I do something by myself or should I go to the apple store?
at&t is a slow network. If the GPS doesn't work, move very far away and wait for a while, then it should work. If it doesn't, then contact apple at 1-800-my-apple
Nov 18, 2009 | Apple iPhone 3G
My iPhone 3g with navman s50
You will need to update your navman firmware
If it is a old model gps check the navman site for compatability.
Aug 04, 2009 | Apple iPhone 3G
GPS Not Activate in my iPhone 3G 2.1 Firmware
yes you can jailbreak your iphone and upgrade to firmware 2.2 this will unlock your iphone to any sim card and shoud enable your gps again ask this bloke at the link click here he is a genius with everything to do with iphone's
Dec 25, 2008 | Apple iPhone 3G
Iphone 3g
gps needs a connection to the internet to work. Iphone bluetooth is very limited.
If you are talking about gps like car gps and connecting it to the iphone through bluetooth, then you will need to update your firmware on your gps and hope that they added the iphone to that firmware. I cant see why not these days
Nov 04, 2008 | Apple iPhone Smartphone
GPS not working
Try this -
Jul 14, 2008 | Apple iPhone 3G
IPhone vs. iPhone 3G
The iPhone 3G has all the features of the first one,
plus faster 3G data downloads,
GPS, and a better battery life.
Externally, the phone's casing is slightly changed, with a thinner edge and thicker middle, but a flush headphone jack and solid-colored back make up the only other major differences visually. Everything else from the screen to the number of buttons and switches on the outside are the same.
Jul 10, 2008 | Apple iPhone 3G
Apple iPhone 3G Logo
388 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
