Nintendo Wii U Logo
Posted on Jun 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Wii u game pad says it can not connect even when I'm a foot or less away from my Wii u. Can you please advise me why it does this?
Mark Schmit
Level 3:
  • Master 1,915 Answers
  • Posted on Jun 01, 2015
Mark Schmit
Master
Level 3:
Answers
1915
Questions
0
Helped
753887
Points
7967
My son has had this problem a few times and usually the result of weak batteries.
Charging pad the remote batteries are dead, won't hold charge anymore...
Sadly that's how they make the new rechargable batteries for controllers. You are supposed to recycle that and buy new. Luckily you can find chargers for the wii very cheap nowadays. I have used a few different chargers and have found the Nyko brand ones are junk so steer clear of those. The Duracell induction chargers however work very nicely. You just set the wii remote down on the charge pad and it charges fairly quickly. My kids run around and even if the remote shifts a bit it will continue charging. Hope this helps!
I have a Pelican dance pad compatible with Gamecube/XBox/Playstation DDR games. Plugging into port 1 of the GC Port on my Wii, I can play DDR Hottest Party 1/2/3 with no problems in any mode, but it...
me too. i get this problem . i have a wii dance pad that has a gamecube connector , and i guess the DDR doesn't detect it as a dance pad , but as a gamecube controller . so think , you can't hold the nunchuck and the gamecube controller at the same time . so i guess we need a wireless dance pad for the nunchuck to work as well .
Connection for Konami Dance Revolution DDR Original Dance Pad for Wii Problem?
If you cant connect in it is probably because you need to sync it. Take off the battery cover for the pad. Now there should be a tiny red button in front of the wii console next to the sd card slots. Press for 2 seconds. now look in the battery compartment for the dance pad. there should be a similar button. press for 2 seconds. now your pad should work as the controller.
Please rate even if bad.
24helpful
2answers
The Wii recognizes my DDR pad until selecting a player
I had the same problem and found the solution: plug it in the first slot (closer to power switch) so that the mat gets linked to the first player^^ (took me a while though...)
The board keeps asking me to step off when I'm not on the board. It won't work with any game. It thinks it has someone on it when there isn't.
Hello :
Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom
(such as carpet), try using the foot extensions
If you are you using the Wii Balance Board on a plush carpet , try using the foot extensions. After you have installed the extensions, re-weigh yourself and check for proper results (within a few pounds.
good luck .
rate please !
3helpful
2answers
What do you do when your wii balance board keeps saying please step off me and press A
Sorry to tell you but it has gone faulty, you need to take it in for repair. There are no serviceable parts inside.
2helpful
How do you sync the drumset for the wii
Turn on the drums (bottom of pads)
Press and hold the Drum Logo until it begins flashing.
press the sync button on the wii as well as on the bottom of the drum pads. That will sync the drum set with your nintendo wii.
Now Rock Out & Bang Away !!!
4helpful
Can't connect DDR pad to Wii system
There should be a flap ontop of your Wii, open it up. There you will see the female part to the pads adapter.
6helpful
2answers
My dance mat is not registering my moves.
I had the same problem and was about to take the game back. Then I changed the port I had the mat plugged into from the first one to the last one and viola! it started working!
2helpful
Wii Fit instructions for movements are all in reverse
No it is not how Wii Fit is supposed to be. First, let me suggest that you ensure that the power button on the Wii Fit Balance Board is facing AWAY from the TV set. This may seem silly, but it's the most common error. As for the Hula Hoop game, make sure that your weight is all on the side of the Wii Fit Balance Board in the direction that you need to lean to catch the hoop.
There have been instances of the sensors in the Wii Fit Balance Board going out. If you have tried the above steps and you are still getting errors, please go to www.nintendo.com, register your product, and open a problem ticket with them.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
