Let me take a shot at this. I am unable to view any context to your statement. I presume you would like to have an easy way to remove the pine needles. From experience I can share with you that a leaf blower works very well. The other solution involves what got George Washington in trouble with his father. That is a hatchet. A very permanent solution to remove the source of the pine needles.
You have powdery mildew. Powdery mildew arises during dry weather and is most likely to attack when temperatures are between 60 to 80 degrees Spraying the affected area with water helps wash spores off the tree. Fungicides can be used to protect the tree or as a preventive to keep powdery mildew from forming. Pruning to remove infected areas.
My inclination would be to get rid of the bugs and store my rice in a sealed container from now on and not keep it around for too long either. Search for bugs in rice on google or similar.
That's the antifreeze entering and exiting the heater core, which is located behind the glove box of the dashboard. If there is sweet smell or antifreeze on the inside floor on the passenger side, you have a leak in the heater core.
You may have the ductwork of the cleaner plugged up with the pine needles. First, unplug the hose from the cleaner and find if you have suction into the bag. If so, check the hose and ducts for blockage from the pine needles.
sounds like the drains are plugged up in front of windshield open the hood and look to see there may be leaves pine needles etc if you have access to an air compressor find the drain holes and try blowing them out
