Hi :)
This may work and its only a few simple clicks :) but it will take less time then re ordering you pages :)
IN the printer settings or Print preferrences there should be a tab for "Advanced settingings"
Go to Control Panel and select "Printers"
Select the general tab and at the bottom of the window select "PRINTING PREFERENCES"
another window will open
from here select the Advanced tab
Find Layout Options in the list
click it you should see "Page Order" and a drop down menu for front to back or back to front.
switch it to whatever order it is that you need and test it out.
or if that doenst work try this:
Set the most frequently used copy
settings as the default. This includes changes to Copy Setup options in
the menu system, as well as other front panel copy settings.
Make any desired changes to the copy setup from the menu or the front panel copy option.
Press
Menu
Press
, then press
. The settings are now saved.
these are the only ways I have found to correct the problem.
