Fuji FinePix S5700 Digital Camera Logo
Question about Fuji FinePix S5700 Digital Camera
Fujipix S5000 screen is all white
Fujipix S5000 when u turn it on the screen is all white and so is the view finder.
Posted by bresam11 on
Anonymous
  • 32 Answers
Suggest you book a repair for this problem at: http://www.fujifilm.co.uk/technical/camera_repair/
Posted on Aug 16, 2009
Anonymous
I just started having the same problem with my S5000, also.
Posted on Jul 11, 2009
The dangers of non Fuji power supplies
This is not a DIY job, you need a FuJi digital camera repairer.
1helpful
I have a fugi fine pix, when using it in bright sun light i cant see anything
Geofchaam,
You could be experiencing one of two issues:
1) You are having a difficulty viewing the image on the back of the camera (not the view finder). This is common on cameras out in the sun, try cupping your spare hand over the screen to cast a shadow on the screen.
2) You cannot view anything in the view finder. Since the view finder has its own tiny LCD display inside of it, it is displaying what image the camera will take if you press the shutter release. I would double check to see if the camera is set correctly for shooting in bright sunlight (check your owners manual, or set the camera to Automatic), and if there is a difference between what you're seeing in the viewfinder, and what images the camera is taking, consider calling Fuji, as it sounds like a hardware issue.
Looking at the screen and through the view finder, all looks green and purple? How can I fix this, I changed a setting somehow
I just tried changing the film type settings on my S5000. (the blue button, standard,chr, b/w) None of those changed the colors to purple and green. It may be that the camera has a failing CCD. It would be a rather expensive repair and not a DIY.
My s5000 screen is all white in record mode. It breifly had a picture then when I pushed the shutter it went white again????
Does the EVF work? The small view finder above the LCD screen. You can switch to it using the EVF/LCD button on the right side above the main display. If it is okay then you'll likely need a replacement LCD.
I had Fuji S5000 for about 3 years. It worked fine. Now all sudden, I can't see any image when trying to take a picture. Both image through view finder and on LCD are just blank. Someone told me that a...
Hi
I have got an S5000 that I can still view previously taken pictures from the card, but when trying to take pictures the screen and view finder shows a peculiar distorted purple and green picture and any picture taken is just a green blur.
I contacted Fuji and they say they can repair it for £90 (about $120)
2helpful
Screen white, pcitures white when I take them. Can view stored pictures from card,,,batteries new
call Fuji and tell them that you would like to send in your Finepix to see if the cheap/defective SCR chip was used in your model. If so, they will fix for free.
5helpful
Blank Screen
dear sorry to tell u but ur FUJI S5000 have a CCD HR failure which is due to the manufacturing fault in these CCD'd thats y fuji now adays stopped working on these CCD's and got tons of recalls for that it occurs after 4 to 5 years of use and this fault was present in all cameras manufactured between 2002-2005 , the ccd offcourse u can check with fuji try hard to get it replaced free of charge other wise consider buying a new one it is not that much expensive there new model as compared in those days it is around 250-300 $ a better version of this , pls vote me generously if u think i helped u
Need to download FujiPix S5000 into my computer..
Need to download installation for my camera into PC?
Problem Transfering Photos to PC
I have a Fuji FinePix S5000 Digital camera with a broken LCD screen. I can take pictures thru the view finder but can't see on the LCD screen. How can I get it fixed and how costly would it be?
4helpful
Fuji S5000 will not diplay object on LCD Screen or Eye View
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager. check it out.
Open Questions:
See all Fuji FinePix S5700 Digital Camera Questions
Top Fuji Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve Nordquist
Steve Nordquist
Are you a Fuji Camera Expert? Answer questions, earn points and help others
