Question about Carrier Heating & Cooling
In the cooling mode for zone 1, why won't the temperature stay as set on the cool setting?
I have a two zone Carrier comfort zone 11 thermostat controlling a section of our home. the temperture on the cool setting continues to cool to less than set on the thermostat. I have tried to reset the tempertures for both heat and cool but still will cool to cooler that set on the unit.
Posted by terry wilcox on
Thomas Woodburn
  • Carrier Master
  • 2,410 Answers
Possibly 2 different scenarios, 1, your tstat is overshooting do to what is called temp droop. This means your tstat will allow the unit to overshoot temp set point to reach the desired humidity setpoint (typically a max of 3 degrees depending on the setting) or 2, the damper for that zone is not closing when set point reached.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Feb 16, 2018
Andy
    Loyalty:
    Visited the website for 30 consecutive days.
  • 572 Answers
If it 2 degree cooler then that's fine .adjust your thermostat 2 degrees higher so you will get the temperature
5 Related Answers
the dr
joey shearer
  • 447 Answers
SOURCE: Carrier thermostat
I hate to say it but Ive had trouble with Carrier's Tstats doing similar improper things. Unfortunatly the only repair is going to be replacement of the whole tstat. I recommend Honeywell's FocusPRO or VisionPRO tstat. Ive yet to have one fail and they have a 5yr warranty if they ever do.
Posted on Nov 26, 2007
jumptrout51
steve
  • 3361 Answers
SOURCE: Carrier Comfort 13 Puron model 24ACA3 / FV4NB006
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Posted on Jun 08, 2009
Anonymous
  • 38 Answers
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Posted on Jun 30, 2009
Anonymous
  • 22 Answers
SOURCE: Carrier Comfort Zone II Smart Control in one zone
sounds like your zone control tstat needs calabrated or maybe replaced,in owners manual there should be a section on calibration if not you may have to replace it
Posted on Sep 15, 2009
little bulls
  • 22 Answers
SOURCE: Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Posted on May 06, 2010
Where can locate the reset button on Carrier air conditioner model Goodman CKL49-1
Follow these 5 steps to restart your AC safely and get your comfort back.
  1. Step 1: Turn off your AC at the thermostat. Go to your thermostat and set it to "off." ...
  2. Step 2: Find the circuit breaker box. ...
  3. Step 3: Reset the AC's circuit breaker. ...
  4. Step 4: Wait 30 minutes. ...
  5. Step 5: Turn the thermostat back to "cool"
Jul 14, 2018 | Carrier Heating & Cooling
I have a Carrier Comfort Zone II with 2 controlled zones. The floor with just the sensor controls perfectly. I set that zone at 75 and it stays at 75. The other zone has the actual thermostat. If I se
Sounds to me like a bad damper or a bad zone panel. Turn tstat off and call for cooling on zone 2. Then see if your still getting cool air to zone 1.( where the main tstat is)
Jul 15, 2017 | Heating & Cooling
How do I connect a 24v damper motor with 6 colored wires red white yellow green blue black to NO COM NC terminals.
Choose two colors of the thermostat wire, and connect them to the NO and COM and connect them to the zone control board leads for the zone intended. Almost all zone valves spring return open when deenergized. So ensure the zone valve is open with the system is off. At the base of zone valve there is a set screw that needs to engage the damper valve shaft in the open position with the motor in the spring release position. Most zone valve are 90 degree moment from full open to full shut. If you have a Carrier zone valve, they go full open to full shut in 45 degrees of motion. Your open stop need to be set so the valve stops in the full stop position.
To help understand the operation of a zone system, say you have 2 zone system and zone 1 thermostat initiates a heat or cool demand. Zone 2 valves energizes and shuts and zone 1 stays open and allow air to heat/ cool zone 1. If zone 2 thermostat simultaniously initiates the same heat/cool demand, the zone 2 valve opens and both zone heat/cool. When either thermostat is satisfied the opposite zone valve closes and when both thermostat are satisfied both zone valves open.
Hope this helps you understand zone operation. The same works for higher multizone systems.
Jul 27, 2014 | Honeywell Motorized Small Rectangular Hvac...
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
Penguin a/c
the multiple zone thermostat should work fine but sounds like this one has an internal failure try replacing the thermostat
Jun 21, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
81 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
