Question about Vizio Televison & Video
47' (sic) LED TV, model number m470vse. Why doesn't the backlight work?
I have a black screen with sound and the Vizio logo turns on, I did the flashlight test and I have picture, replaced LED driver and still no backlight
Posted by Jessica Rodriguez on
    Top Expert:
  • Vizio Master
  • 76,466 Answers
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Posted on May 30, 2015
I have a Vizio TV E500i-B1 and the screen is black when powered on. I have sound and able to see images with a flashlight. what do I need to do to fix it?
You have lost your backlights, look at the inverter board if its a LCD or with LED the power supply that supplies the voltage for the lamps
Nov 13, 2017 | Vizio Televison & Video
I have a 32 vizio e320-a0 with a black screen with sound
probably the tv have problem with its back light, you have to check and replace the led driver. Che the video to more about back light.
Samsung TV Repair Part Number Identification Backlight Inverters LED...
www.electro-medical.blogspot.com
Sep 21, 2015 | Vizio E-series E320-A0 - 32" Class 31.5"...
Vizio tv model e420vse turns on and then screen goes black. Still has power and sound. If I turn off and back on, the picture will come back for a few seconds and then shut off again. Vizio suggested it...
There are a lot of references on how to repair the LED backlight. If you can source the parts, google search LED backlight repair.
You may wish to read this first: http://www.techlicious.com/blog/un-repairable-vizio-tvs-leave-customers-out-of-luck/
Mar 31, 2015 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
How to fix vizio tv
The backlight is LED and not likely to fail, it is most likely the main, modular power supply causing the problem.
Look inside for a block assembly with larger components and several connectors that is bolted onto a larger panel.
These are purchased from other sources, not made by Vizio.
Look into the guts of this assembly for cylindrical components with plastic foil and an aluminum top, mostly mounted vertical to the board.
Examine the tops of these for any dome-like appearance; this is a sign of failure since these should be flat.
They are inexpensive (one reason they fail) and this failure can be prevented by spending another dollar or two in the manufacture of them.
Replacements can be had but unless a couple of parts are added (by the maker or a smart tech) the same failure will eventually occur.
Dec 26, 2014 | Vizio M470VSE 47" LED TV 1920x1080, 120...
Parts needed for VIZIO TV with backlight out
You can fix it if you have some repair experience, you will need the power inverter board and/or the backlight lamps of the LCD screen, first try the power inverter board, the function of it is to up the voltage from 12/24/48V to a 800-1500V needed for the LCD back lamps.
Nov 17, 2014 | Vizio XVT473SV 47 in. LCD HDTV
Why won't Vizio Tv come on?
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the unit and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Sep 16, 2014 | Vizio M470VSE 47" LED TV 1920x1080, 120...
Vizio VO47L FHDTV10A black screen no light
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Vizio VO47L 47 in. LCD TV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
158 people viewed this question
Top Vizio Televison & Video Experts
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
