Question about HP Officejet 7210 All-In-One InkJet Printer
Carriage jam I had a small paper jam - which I thought I fixed by removing all the jammed paper -- and now I can't get rid of the error message "carriage jam. open door. clear carriage jam and then press ok." I've double checked that there is nothing still stuck in the printer; i can't see any paper, etc. I've turned off the power to the printer, re-booted the entire PC, and still no luck. Any thoughts?
Posted by kmann on
  • 3 more comments
  • purify Nov 19, 2007
    same problem but where is the door? i'm useless
  • Anonymous Nov 27, 2007
    my carriage will not move to the right side of the printer allowing me to remove the cartridges.
    Ughhhh!!!
  • Jehkobi Nov 29, 2007
    My HP7210 All in One Fax copier Scanner is indicating paper jam but I have removed the paper and restarted the copier and the paper jam esclamation sign is lit. How do I resolve this problem
  • Anonymous Jan 08, 2008
    after a document has completed printing, i hear a sound and the printer jams. it reads carriage jam." please help. thanks. todd
  • Anonymous Apr 03, 2008
    I was attempting to copy on card stock, paper jammed, some paper still stuck in machine but I cannot see it. How do I open the machine up entirely to find paper and clear jam. I can open the top but I still cannot see the paper.
Anonymous
I have the same problem i have a carriage jam problem please tell me how to fix it i have a mesage clear carriage jam and then press ok.
Posted on Jan 21, 2008
Ben Johnson
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Try this...
Posted on Oct 26, 2009
Anonymous
If you take the print carts out you can see a copper coloured belt behind the cartridges. Pull this so the cartridge slots move all the way from one end of the carridge to the next. This fixed it for me.
Andrew
Posted on Oct 01, 2008
Anonymous
Power down the fax machine for 30 seconds. Push # and 6 simultaneously and power back up.
Posted on Dec 12, 2007
Started with paper jam and then after that. Error message. Carriage Jam, print carriage access door. Clear and press ok. can't figure out what this means
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5821600-carriage_jam_open_door_clear
Aug 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
My printer is giving me 2 error messages. One is
For the cartridge jam, that means that either the ink is not properly installed or there is one tiny piece of something blocking the sensors. Same is true with the carriage jam.Please try to look for small bits of paper and remove it.
Is the ink newly installed?
Aug 08, 2009 | HP Photosmart C5180 All-In-One InkJet...
Carriage Jam -- Paper Jam
I have serviced an officejet pro L7580 which was showing a paper jam error when powered on. our customer had had a paper jam and removed the paper . I found small peices of paper in the pick up assy gears. If you remove the rear door, you need to check the 2 small white gears on the left. turn the roller slowly by hand and clear any paper stuck between the teeth. (they may be very small).
after doing this....no more paper jam errors for me!
Jun 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Apr 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
839 people viewed this question
Ekse
efs_perpends
efs_perpends
