Question about LG Refrigerators
Schematics for lg lfx25960st
Schematics for lg fridge to find relay switch for compressor or location of computer control board
Posted by Bertie Baumgartner on
Stopped working. clicking sound when it wants to start up. Is it the compressor or the relay switch model 8 yrs old old.
You.have to check if the compresor is working or damage. Try starting direct the compresor, Generali should be the electric part outside the compresor just change at the electric parts and should work. If you send a picture of the position on the connectors I will help you to try the compressor
May 29, 2015 | LG LFX25960ST Stainless Steel French Door...
Why does my lg refridgerator not cool down?
I can only think of three things that might cause symptoms like that - first is a bad compressor. Second is a low refrigerant charge. Third is a malfunctioning defrost timer, which is a little circuit board hidden in the back of the freezer or refrigerator, accessible only from inside the freezer or refrigerator. There would be an access panel you could unsnap or unscrew to get to it. Those timers tend to be pretty problematic.
Jul 31, 2014 | LG LFX25960ST Stainless Steel French Door...
I have a LG refrigerator model no. LFX25960ST that stopped working. All my meats in the freezer defrosted and the upper fridge is also warmed. I can hear the fan running. I unplugged it and plugged back...
it is not a great idea turning a fridge off and back on straight away. It will overload the compressor and cause it to trip out. I would suggest that the starter relay has failed on the compressor but if the fridge has been left to cycle on and off too many times, it will damage the compressor. Turn it off and get a fridge tech to look at it and confirm the fault.
Jan 28, 2018 | LG LFX25960ST Stainless Steel French Door...
My LG fridge is not cooling after 3 days. when i switched ON after 1 week it cools back, but then after 3 days its not cooling again. I dont think its the heater or defrost sensor since both the upper and...
You may have a problem with the compressor relay switch or the control board. Run the unit until it stops cooling. Go into the back and see if the compressor is running. If not, check for voltage. If there is voltage, then replace the relay start switch. If there is no voltage, you will need to check the control board to see if there is voltage going to the relay switch.
Jun 28, 2011 | Refrigerators
Refrigerator light stays on ?
LG has a wonderful way of turning on their refrigerator lights, they have the control board do it. Very nicely done in theory but in reality I would trust a handy door switch to control the light on/off function then a relay that get's stuck. That's right, the relay is stuck on the control board. Pull light bulbs out quickly before plastic melts on the inside top panel of fridge. Call LG, it should be covered under warranty.
Nov 24, 2010 | LG LFX25960ST Stainless Steel French Door...
My LG refrigerator LFX25960ST has the light shuts off and stays on untill it over heats. I took the light out and have been looking for a diagram with the exact part that I need. I reed that its the relay...
The control board has relays on it that are not user replaceable unless you can solder. You also must be able to find them since they are integral to the control board. I have attached the board info to this post. I would change the door switch before I changed the control board. http://www.appliancepartspros.com/lg-main-electronic-control-ebr34917104-ap4450216.html
Nov 27, 2017 | LG LFX25960ST Stainless Steel French Door...
What does if mean when the display reads ER CF code on my LG LFX25960ST fridge?
it means there is a fault with the units compressor fan you will notice the fridge is running with less noise you will need to call a service man to come fix it good luck
Apr 21, 2010 | LG LFX25960ST Stainless Steel French Door...
My LG 22850 fridge light stays on all the time
Contacted LG Canada they were great just gave them the serial number of my fridge and are coming out to replace the parts no charge (the fridge is
way outside warranty)
Dec 31, 2009 | LG Refrigerators
Refrigerators Logo
245 people viewed this question
Top LG Refrigerators Experts
Michael Thomas
Michael Thomas
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
