Question about Locks & Locksmithing
TSA 007 lock that comes on the luggage's reset button is stuck. Can't set new lock numbers as it wont spring back to the original position after setting new combi. What can I do?
john h
    Top Expert:
  • 23,424 Answers
Internal spring broken or jammed try tapping to see if spring pops back
Posted on Aug 11, 2017
2 Related Answers
Anonymous
SOURCE: Set luggage lock
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
Posted on Jan 03, 2009
alpug
Danilo Baraquiel
  • 1961 Answers
SOURCE: I have a new Nubbio
You can not reset your lock combination without knowing the original combination you had set.
If you have forgotten your lock combination, then there are 2 solutions.
1. You could use Bolt Cutters to break the Lock open.
2 . Sometimes, the simplest solution is often overlooked, as your lock is a 3 digit combination lock, and if you have about 30 minutes to spare, then why not try all the possible combination from 000 - 999 ( 000, 001, 002, 003 through to 999) You may think this will take a long time, but it should not take you more than 30 minutes and if the first digit of your forgotten code starts with a 0, 1, 2, or 3.. then it will take significantly less than 30 minutes. Try it out, as it will save you from having to buy a new lock if you use bolt cutters.
This is a helpful link that I can give you.
http://shop.heys.ca/help_answer.asp?ID=19
Posted on May 28, 2011
How to set a combination on a Samsonite 3 dial combo lock
How to set a 3-dial luggage lock - YouTube
? 1:22
https://www.youtube.com/watch?v=TI4AgFhcnys
Sep 16, 2017 - Uploaded by Distant Lands Travel Store
http://www.distantlands.com How to set luggage locks. Simple and easy instructions on setting luggage locks.
3-Dial TSA Lock® & Cable - YouTube
? 1:21
https://www.youtube.com/watch?v=QlysHXuaftY
Jun 28, 2012 - Uploaded by Eagle Creek
it comes with a 50 inch cable. so that you can use this combination to go ahead. and secure different pieces of ...
How to Reset a Samsonite 3-Digit, Built-in Combination Lock ' USA ...
traveltips.usatoday.com > ... > Vacation Excursions > Things to Do on Vacation When purchased, the locks are set on a factory default combination that you can change as often as you wish. Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage. Locate the reset button, usually placed to the side of the combination dials. People also ask How do I reset my Samsonite luggage lock?
How do you open a combination lock without the combination?
How do I set the lock on my Samsonite suitcase?
How do you change the combination on a TSA lock?
Feedback
Lock Instructions - Samsonite
https://www.samsonite.ca/lock-instructions.html Luggage locks approved by the TSA have a universal master key that will open the locks (the keyhole you will see on your TSA lock, when you have not been provided a key ... Every TSA approved lock has an identifying mark that shows it may be opened by the master key. ... Have the lock set on your original combination.
Mar 17, 2018 | Samsonite Photography
How to Reset t tsa lock on a Mia toro luggage
How do I set a Mia Toro luggage lock? - Fixya
www.fixya.com/support/t26581106-set_mia_toro_luggage_lock
Apr 30, 2017 - Release the reset button after you set the numbers to the new combination. ... If you still can't open the lock, contact Samsonite Customer Service at .... TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to ...
Amazon.com: Questions And Answers: How do you set the luggage ...
https://www.amazon.com/forum/-/Tx1WRFLRQIYMJR0/ref=ask_ql_ql_al_hza?asin... Jun 20, 2016 - Mia Toro Metallo Composite Hardside 26 Inch Spinner, Blue, One Size ... The factory setting is 000 make sure lock is set to this press the reset ...
How to Set A Luggage Lock / LuggageFactory.com - The Travel ...
https://www.luggagefactory.com > ... > How to Set A Luggage Lock Sep 10, 2014 - TUMI: TSA Combination Padlock: Make sure the combination is set back to (0-0-0), the factory setting if new, or the existing combination if it has been used already. Make sure the mechanism is unlocked. Press and hold the button on the side of the lock. Select a new combination.
how to Reset tsa lock on Mia toro luggage Google Search
Jul 26, 2017 | Locks & Locksmithing
TSA opened our lock on our Delsey luggage, I now am unable to lock the suitcase. How can you reset the lock on the Delsey luggage after unlocked by TSA?
1. Look for a small recessed button below (on the bottom side) the TSA key access.
2. Push in the button with a paper clip or pen.
3. While the button is pushed, change the combination to the desired numbers.
4. Then release the button and the combination has been reset.
I also found this, but it needs to be open/
http://www.ehow.com/how_6927475_reset-tsa-lock.html
Dec 08, 2015 | Delsey Helium Shadow - 25 Trolley Luggage...
HEYS TSA LUGGAGE LOCK WONT LOCK PLEASE HELP I THINK I MIGHT HAVE BROKEN IT
Try all the combinations. To save wear on your fingers, use a small screwdriver to dial the numbers. Try to open it after changing each digit. You can try all 1000 combinations in about twice the time it takes you to count to 1000 out loud, but unless you chose a combinations like 998, you will probably open it long before that time.
Jan 27, 2015 | Locks & Locksmithing
Hi there I have a Tripp suitcase with a tsa007 yif lock The customs people at the air port opened the suitcase and now it won't lock How can I make it lack again Please help It's a relatively new case that...
Take it back to the airport and ask to speak to TSA and tell them that it was opened with the master key. Have them return the lock to its original position by turning the key.
Feb 19, 2014 | Luggage & Travel
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
I have a somesonite 30in hardshell , uprite about 20 yrs old. has 2 key locks, as well as combanation center lock. question how can i set these locks so that, they are TSA excessable locks??? PLS. Help ...
You can have the locks changed but, that will cost almost as much as new luggage. They will have to be kept unlocked and a TSA strap will be needed around the suitcase.
Oct 07, 2010 | Samsonite Silhouette 11 Hardside Spinner
Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Nov 08, 2009 | Samsonite Tripod
Locks & Locksmithing Logo
8,474 people viewed this question
Top Locks & Locksmithing Experts
john h
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
