Question about Kyocera Km 1620 Cs 1620 Copiers Copy Machines Copier Commercial System Printer
How do I fix A-4200 problem on KM - 1620 Kyocera copier
This copier indicates A-4200 on start
Posted by Goddiy on
Samar Luwang
    New Friend:
  • 9 Answers
Try the main charge first...if not working Replace the laser unit.
Posted on Aug 18, 2015
Kyocera KM 1620 the problem is show A-4200 how can i solve it? plzz help me
Refer to the user manual Troubleshooting section for an explanation of the same .
Jun 26, 2015 | Kyocera Office Equipment & Supplies
How do I fix C-4 on KM-1620
please switch off the printer and switch on the printer and check it
May 28, 2015 | Kyocera Km 1620 Cs 1620 Copiers Copy...
How do I reset my KM 1620 Kyocera copier.
Causes:
1. Unstable power source
2. Low/High voltage
3. Broken thermistor wire
4. Poor contact in the thermistor connector terminals.
5. Heater lamps are broken or not installed correctly.
Before resetting "6XXX" series code, make sure that defective parts have been replaced/repaired.
Reset Procedure:
Enter 1087-1087 (1087 twice) from the keypad.
Enter 163 by using keypad.
Press "Start" (the green button) twice.
The machine will restart automatically.
May 21, 2015 | Kyocera Km 1620 Cs 1620 Copiers Copy...
Hello how do I fix A-4200 problem on my copier Kyocera KM-1620?
C4200 CODE IS FOR A LASER UNIT PROBLEM, IF IT WONT
RESET BY TURNING IT OFF AND ON THE LASER UNIT NEEDS
TO BE REPLACED. EXPENSIVE PART FOR A COPIER THAT OLD.
May 21, 2015 | Kyocera Mita KM-1620 Toner Black...
How do I clear A-4200 on a Kyocera copier KM 2016
A C4200 IS A BAD LASER UNIT , EXPENSIVE REPAIR FOR A COPIER THAT OLD.
May 21, 2015 | Kyocera Mita Drum Cleaning Blade Km 1620...
What make the buttons of my Kyocera Mita KM 1620 stop working
the buttons stop working because the internal pressing are crash and you should replace it or join it by welding. but first of all you may blow the panel it could be some dust.
Sep 18, 2014 | Kyocera Mita KM1620 Black Toner Cartridge...
CAN KYOCERA COPIER KM - 1620 BE USED AS APRINTER
no sir km 1620 is basic copier machine. for printer series you should go with km 1635/2035/1650/2050 or the newest one taskalfa 1800
Mar 13, 2014 | Kyocera Office Equipment & Supplies
Error code A3200 for kyocera km 1620
how to repair kyocera km 1620, showing error message "A3" "200"
Mar 31, 2013 | Office Equipment & Supplies
Kyocera KM-1620 as a printer??
Yes, it can be connected as a printer -- see this page where you can download the print drivers:
http://usa.copystar.com/americas/jsp/Kyocera/download_center.jsp?pid=11917&pcat=10564&rcid=10009&rscid=10007#bottom
However, it may need an optional interface attached. Check the back of the machine to see if there is a USB port (the squarish one). If there is nowhere to plug in the USB cable, you may need to buy the printer interface option.
Jul 07, 2010 | Kyocera Copystar CS-1620 Black and White...
Kyocera Km 1620 Cs 1620 Copiers Copy Machines Copier Commercial System Printer Logo
326 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Timothy Van Der...
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
