Lights 1 and 7 (light 1 being 'long wash' and light 7 being between rinse and spin!)
Error code 130
Watch this
Fisher and Paykel 130 10000010 Error Code Fix
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
