I need sound card driver for IBM NETVISTA PENTIUM 4 MOTHERBOARD, 25P5090 nowwwww!!!! please.
Yes, you can.
When the system is installed, the first thing that you want to do is adjust the visual effect of Windows for best performance. Next, then select the classic mode. Then, go start, run, and type regedit
In the registry go to HKEY Current Users Control Panel Desktop If the registry key MenuShowDelay doesn't exist, create a string and enter a value of 0. Also, you can create a string, if it doesn't exist, HungAppTimeout and set it to 1000
Also, type msconfig in the run dialog box. Uncheck unneeded programs that you don't want to start up. Sound icons will have to be deselected through the control panel.
Also, go through the control panel of Windows and go to the display and make sure that the fade effects are not selected. Only the Alt select is enabled.
Also, go the the computer management, services and uncheck also certain services that you do not want to run. Just make sure that they are not critical windows services. Check the internet for these services.
When this is all completed, you can run Windows Vista on about 550 MB of RAM. You will definitely have to upgrade your RAM, but at least this is a start.
You can install but install wizard will tell you to upgrade sections that do not meet minimum specs (ie Ram and HD)
If it does install then it will be very slow on the Ultimate edition...possibly try the basic or home edition OR go to XP with SP3....just as good
You can install it but at initial step you will asked for ram upgrade of HD space. Try to upgarde your ram first.
It will surely install but it will be very slow in the operation because your system does not meets the minimum requirements you will have to upgrade your ram and graphics card to run it optimally
also
some programs you use will also run slowly
so reccomend you
vista home basic
or
xp sp3
additionally you can insrtall various customization packs to enhance the xp gui
1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
16 GB available hard disk space (32-bit) or 20 GB (64-bit)
DirectX 9 graphics device with WDDM 1.0 or higher driver
If you want to run Windows Vista on your PC, here's what it takes:
1 gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) of system memory (512 megabytes (MB) for Home Basic)
40 GB hard drive with at least 15 GB of available space (20 GB for Home Basic)
Support for DirectX 9 graphics with WDDM and 128 MB of graphics memory (32 MB for Home Basic)
DVD-ROM drive
