Power Acoustik POWER ACOUSTIC PD-931NBT NEW SOURCE UNIT W/ 9.3" TOUCHSCREEN & ANALOG Logo
K
Kut-N-Up Posted on May 28, 2015
I need to reset my touchscreen car radio everything froze and the screen just stopped working
Is it possible to replace or repair the touchscreen?
Possible but may not be cost effective. Internet search for the part number on your screen is your only hope on this one.
When i turn on the car the radio doesnt go to the home page it goes to a screen with circle and arrows number 1234
You have the unit wired wrong. When you shut your key off the radio loses ALL power and it needs ACC power to maintain the memory. If not, the unit will reset itself. The screen you see is the touchscreen calibration screen. Just follow the " X " around the screen to 5. Then the unit will boot up again. You will have to reset radio stations and EQ and speaker settings. If you don't fix the ACC wire, you will have to do this A LOT!
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Keeps showing lg screen and flashing
Android is corrupted. You need to factory reset it. Hold volume down and home buttons while turning it on. You can let go of those buttons once the screen changes to the Android loading icon.
This will erase everything from your phone - so good idea to keep things backed up for incase it happens again.
Near as I can figure, this happens when:
- phone battery is allowed to die
- pull battery from phone when it is still shutting down (hard to tell when it's finish)
5helpful
Google play stop working on my irulu pad, it just says no connection
you have to reset the tablet to factory conditions. i was at my wits end before i did this. o stay away from opera, firefox, and chrome there are other browsers
It just froze and it stop working i reset it but it is frozen (bv7300 car dvd stereo)
Ok, a little more description is needed to help. When you say "froze", do you mean a dvd image froze on the screen or do you mean that all functions have ceased to operate. If you reset didn't work, you will need to old school it. Remove the radio from power completely for about 15 minutes and then reinstall. See if that helps. The other variables are how long you had the equipment, did you purchase new, did you buy from someone else, did you install or have it professionally installed. These are things that can help with warranty issues too. Good luck.
2helpful
Mp4 touchscreen is froze what will i do?
The problem with your MP4 Touchscreen is the storage (memory card). There could be some bad sectors in the storage that's why it was not detected by the computer everytime you're plugging it.
If the device is still under the warranty, you need to contact the manufacturer and have them repair it. Aside from replacing the storage, they also need to upgrade the firmware of your device.
That should work again.
3answers
Touch Screen and Remote Problem
My remote stop working. I replaced the 2 AA batties by still does not work
Top Power Acoustik Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Power Acoustik Televison and Video Expert? Answer questions, earn points and help others
