Question about SVP Aqua Wp 6800 Underwater 18 Mp Digital Camera Black Waterproof To 3 Meters
How does battery boor open? I tried the black latch to no avail.
I opened the box, got camera out, but can not get battery door to open. Do you have a remedy for this problem?
Till then I have a new camera that is useless.
Posted by Ralph Gammon on
1 Related Answer
Terry Corrow
johnny rebel
  • 10875 Answers
SOURCE: Why Does the battery door not open
put some muscle into it
Posted on May 27, 2015
How do i open the battery door on the M-888
If you mean the Moultrie M-888 mini game camera, you need to open the camera cover and then press a release button on the front of the camera to open the battery tray on the bottom of the camera. The release button is in the center at the bottom of this section of the camera. If the release button isn't working, then you need to discuss the problem with Moultrie.
The manual for the camera is available on the Moultrie product site: http://www.moultriefeeders.com/moultrie-m-888-mini-game-camera . Click on the Downloads and Manuals tab. The direct link to the manual in English is http://www.moultriefeeders.com/media/downloads/1733/M-888%20(2016)%20Series%20manual_ENGLISH_11-23-15.pdf . The release button is shown on page 1. The quick start information is on page 5.
I hope this helps.
Sep 30, 2016 | Cameras
Can I replace the latch or change the full internal chamber?
sir,
this part is available with Nikon agency, to replace this you have to open the whole camera, then detach the front portion, it doesn't matter, just a piece of rubber or sponge fix on the battery lid, this will be help full to hold the battery at contact perfectly.
Jan 09, 2016 | Nikon 1 J1 Digital Camera
Golf tdi wagon rear boor wont latch
check to see if the latch is not already half closed. If so use a round bar( Phillips screwdriver) that will fit under the latch and pull out while trying to open the door
sometimes the latch will move to half closed and will be in the wrong position to fully engage the retainer
Feb 25, 2015 | Cars & Trucks
None of the doors open
The latches are "frozen" because of metal contracting in the latch or latch lubricant physically becoming more viscous or freezing and preventing movement of the latch. You may need to apply a sub-freezing lubricant to prevent them from freezing up in low temperatures. Best put the car into a garage and let the general higher temperature unfreeze the latches.
Feb 02, 2015 | 1995 Pontiac Bonneville
Open camera
Looking at the bottom of the camera, slide the oval latch in the center of the card/battery compartment door toward the back of the camera. Holding the latch there, slide the entire door toward the nearer end of the camera, and the door will swing open.
To remove the memory card, press down on the card and it will pop up a bit. Grasp it between your fingertips and pull it out the rest of the way. (It'll probably be easier if you let the batteries fall out first.)
Jan 09, 2012 | Nikon COOLPIX L20 Digital Camera
How to change battery
Hi, try:
To install the battery:
Note: To open the battery door, you will need a paper clip or thin pen.
1. Take the paper clip and use the end to press down on the door latch.
2. Holding the latch down, push the battery door up.
3. The door will slide up and spring open, allowing you to access the batteries.
4. Place the battery into the compartment. Be sure to match the (-) on the
battery with the (-) inside the compartment.
5. Slide the battery cover to its original
Jun 09, 2011 | Disney Pix Micro Digital Camera
My Canon digital Camera won't turn on
I assume you've already gone thru the obvious check and proposed fixes covered in the user manual (battery replacement, contact cleaning, etc). I did all that to no avail after dropping it about 1m onto a concrete floor last nite - after which it refused to power up.
There was no obvious mechanical damage other than a ding on the
rear corner of the battery box door. After disassembly, seeking interior damage, I found a deformed piece of plastic near the door
latch strike that was preventing the door closure switch next to the "MENU" button from fully operating. Some careful tweaking and making a note to push the latch fully closed after use fixed it.
This switch must be operated (opened) in order for the camera to
run. You can verify this on a working A570 by pulling the door latch
partway open, while keeping the door closed by hand, and trying
to power up.
Jan 01, 2009 | Canon PowerShot A570 IS Digital Camera
Film door latch is loose
Same advice I made to another post. At some point you got to make a decision. There is a lot of plastic pieces that can break. Canon doesn't support the T series from what I've read. You may consider getting another one. You also have to consider that the fix may not work. Then what do you do?
Sep 06, 2008 | Canon T70 35mm SLR Camera
Camera died
You may want to try if the little black latch contact next to the battery and the memory card is not working properly. The camera will freeze and not turn on when this contact is not engaged. Open the battery latch, press down on the little black contact using a pen and try to turn on the camera. If so, the latch doesn't engage that contact any more in regular use. If not, no luck. I had this problem and fixed it by putting a small thick piece of tape on the little pin on the latch that is supposed to press this contact.
Sep 02, 2008 | Canon PowerShot SD1000 Digital Camera
SVP Aqua Wp 6800 Underwater 18 Mp Digital Camera Black Waterproof To 3 Meters Logo
53 people viewed this question
Top SVP Video Cameras Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a SVP Video Camera Expert? Answer questions, earn points and help others
