Question about home Audio Players & Recorders
I have a WahlDorf WD-310HT Home Theater without any directions. How to connect to subwoffer an speakers all to TV or DVD?
Posted by [email protected] on
Mister Danger
  • home Master
  • 5,631 Answers
Any tips form here?
WD 305HT 1000 watts system power
Posted on May 27, 2015
5 Related Answers
Anonymous
SOURCE: Panasonic Home Theater SC-PT760
This is not a problem, this means that your system is working. Polar Express was recorded in Surround Sound with separate tracks for each speaker channel. In most movies you will find that the rear speakers will only play certain sound effects so that it appears they are coming from behind you (gun shot, train, fireworks). Most of the diaglouge will come through the center channel and music/effects through the front left and right, with bass coming from the subwoofer.
Now, you can still hear more from the rear speakers if you like this enveloping effect, or if you like your music coming from all directions. There are Sound Effects options to have the front and back speakers always playing the front track, there is Dolby Pro Logic II that turns stereo sounds (like many TV shows) automatically into 5.1 Surround Sound, and you can also individually change the volume of each speaker.
These are all explained on page 29 of your owner's manual under Sound Options. If you need specific button to button help, let me kow.
Posted on Jul 02, 2008
Anonymous
SOURCE: No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
I have a high definition Polaroid tv which I bought in 2007. I have it connected to Dish tv. It worked fine at first. Now when I use the Dish tv remote, the television won't power up. The red light, which appears when the television is off turns blue when I attempt to turn the tv on, but the screen stays black. Why won't the television come on anymore?
Posted on Nov 02, 2008
Anonymous
  • 51 Answers
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Posted on Jan 08, 2009
Anonymous
SOURCE: Apple TV and Bose Home Theater
I had the same problem.
I could not get HDMI to HDMI to work.
i fixed it (work around), by connecting ATV HDMI to DVD HDMI port on V30, i then connect L&R to AUX.  I set the Bose remote for controlling ATV to AUX.
so to use ATV with Bose remote i know press DVD, this gives me the correct display but not audio, i then press AUX and this gives me ATV control and audio.
interesting, when i first set this up (trial and error), it didn't work.  I was doing some cable management clean up, when i got a fright and the thing started working...but i have a ghost in my house so that is probably a more plausible reason why its working now.
it feels like this product is only 90% finished
Posted on May 26, 2009
Anonymous
  • 15 Answers
SOURCE: How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Posted on Jun 02, 2009
How to wire subwoffer to five speakers I've been told how to connect subwoffer to tv
i didnt tell you how to connect your subwoofer to your tv,i told you how to connect the audio unit to your tv,the 5 speakers AND the subwoofer connect to the surround sound audio unit,you DO NOT CONNECT SPEAKERS DIRECTLY TO TV.,
May 27, 2015 | Audio Players & Recorders
I have a WahlDorf subwoffer an five speakers.what do I need to connect to tv
A head unit with sub out tv/ audio in , rca cables, if the tv in on the head unit and the tv, is hdmi capable. a hdmi cable is needed. tv if flat should have rca, and depending on the age hdmi outs just the red and white on the rca cables. You need a pre amp for the sub this is heed unit or tuner if comparing to you car. it breaks the signal down to the amp. plug into the audio in, tv in or (hdmi in depending on your unit, some only have rca ins.) Let me know and show some pictures if you have questions.
I have a WahlDorf sound system no instructions...its WD310HT Home Theater.its a subwoffer an 5 speakers how to connect to TV or DVD?
there is no info for a 310,but,there is for a 305,you need to make some cables for it,you need some rca cables with one end cut off,the rca plugs into the tv audio output,the two wires from each one,go into the push connectors,treat the outside wire as neg(black) and inside wire is always pos(red),,the top 2 push posts on the left are for the left audio from your tv,the 2 posts on the right are for the right tv audio,there are 4 more connectors for another device,like a dvd etc,push connectors operate by pushing in on them and pushing the bare wire into the little hole and releasing,
25715906-ghuqylfbvqx2ddmcce1obb43-5-0.jpg this is the only pic available,the 4 push connectors on the right are,tv right,pos,,tv right neg,then other audio right neg.,,the bottom one is other audio pos,,,,the 4 on the left side are left tv audio pos,,then left tv audio neg,then other audio left nrg,,then left other audio pos,,,
25715906-ghuqylfbvqx2ddmcce1obb43-5-2.jpg this is like what you need,the red is positive and bare is neg
May 27, 2015 | home Audio Players & Recorders
My DAVHDX576WF surround system is connected to my TV by HDMI, but I hear no sound. The home theater test/setup is audible, radio is audible, but nothing from the TV
Which direction do you expect audio to be flowing: from or to the TV? The HDMI is an outbound connection for video. Page 71 describes how to enable the DVD AUDIO ONLY if you really want TV speakers to be competing with the DAV.
http://www.retrevo.com/support/Sony-DAV-HDX576-Home-Theater-Systems-manual/id/13756ag215/t/2/
Sep 10, 2011 | Sony BRAVIA® DAV-HDX576WF Theater System...
5.1 Dolby system does not work with the T.V.
Solution: connected the rear right and left wires to the Front , left and right wires......................and everything works the way I anticipated without any technical problems....... the woofer works on a separate circuit, so I continue to receive the "low" frequency..
Oct 01, 2009 | Memorex MiHT5005 Theater System
Installed new 1080 plasma tv can't get sound from home theater system
A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
Sep 17, 2009 | Audio Players & Recorders
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Subwoffer how to connect it to my amp
You have the M-Audio BX8A speaker listed here. Is this what you have? If so, this is a powered speaker and therefor no need for an amplifier. If you want to use it as part of your 5.1 home theater system, it is not possible to power other speakers with this particular speaker, as it does not have the required output connections.
Jul 23, 2007 | M-Audio Studiophile BX8 Main / Stereo...
928 people viewed this question
Top home Audio Players & Recorders Experts
Kenneth Walker
Marvin
Marvin
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
