Question about Health & Beauty
Scooter is immaculate & little used new batteries fitted but will only do about 1 mph with speed pot turned to full thanks
ADRIAN
    Sergeant:
  • 313 Answers
Check batteries for volts and load test. if ok it could be the motor brushes need attention, speed pot faulty, Wig-Wag faulty. You may need to get professional help.
Posted on Jun 17, 2015
5 Related Answers
gewiz
Rob Hill
  • 1414 Answers
SOURCE: I have a Pride Legnd..the scooter started loseing
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Posted on Dec 15, 2009
Testimonial: "Any insight to a problem is a positive step."
Neil Wood
  • 177 Answers
SOURCE: I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
Posted on Jun 07, 2010
Testimonial: "hello,thanks for ur info.i came to be here by paying for it,then ended up answering questions for others,my scooter is still not working.its a long story but i have learned a lot & have lived my life helping others.i recently downloaded info from shoprider,not having my scooter has depressed me like you wouldnt believe,but i will eventually get it sorted,this is my email if you wish to exchange info,i was punched off my scooter last year & suffered concusion.hence i have a problem getting to grip with things at times.the CPS dropped the charges against the young male 150 people there i had it put in local paper for witnesses with no help lol.gotta laugh whats the point moaning [email protected]"
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: My schwinn s750 elec. scooter
Yes that is quite dangerous and definitely not normal operation . It sounds like something in the throttle itself is not sensing the turn correctly. You are going to want to get the part from Schwinn directly, they will know which part, and can provide the manual to you as well. Their number is 1.706.860.8880
Posted on Sep 28, 2010
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: Batteries are fully charged. Scooter goes at full
Based on your description you have a bad throttle potentiometer or speed potentiometer. Remove the covers of the front console and check the resistance throughout the range of both pots at the connector. It should be even throughout the range with no dead spots. The newer CTE throttle pot is more reliable than the older model Celebrity scooter with the 5K ohm potentiometer. I usually replace the throttle and speed pots as a pair since they are connected electrically in the console.
Load test the batteries while you are driving. Using your voltmeter that is still connected under the rear cover while you are driving, check to see if you get a voltage drop of more than 1 volt. Static testing of batteries only tells you that there is a full charge. It does not give you an indication of how the batteries perform under load.
If you have clean brushes, you can still have a large amount of conductive brush dust in the motor and armature. Blow out the dust with compressed air. Check the motor and brake with you meter. The motor coil resistance should be less than 1.5 ohms and the brake should read between 40 to 60 ohms. Hope this helps.
Posted on Jan 05, 2011
gewiz
Rob Hill
  • 1414 Answers
SOURCE: set to move at 8
Hi, Sadly that sounds like your batteries have called it a day however please check your charger as this can have a fault and this can make your batteries appear weak and the battery teminal connections, are they loose ?. Check your manual as I think you can fit 12V 40Amp batteries to this scooter.
Please leave feedback if my advice helps.
Posted on Jan 22, 2011
I have fitted & load tested new batteries, but feel sure it is not reaching 4 mph. How do I check the speed pot?
Hi U will have to remove the pot & check the resistance in OHM's. with a multimeter good luck
Apr 28, 2016 | Health & Beauty
What makes a speed pot go bad on a celebrity x 3 wheel scooter?
Yup you got a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pot is a variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should move gracefully up to 30k down to zero as the pot dial scooter speed increases. Failure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Jul 23, 2012 | Pride Health & Beauty
What makes the speed pot go bad on a 3 wheel celebrity x scooter
Yup you gt a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pt is aa variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should movee gracefully up to 30k down to zero as the pot dial scooter speed increases. Faaailure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Jul 23, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
My scooter is too slow,the battery charges,but only drives at a very slow speed.While going backwards drives at a good speed.Can you tell what to do??Many thanks Diana Donald
Hi dianaidonald
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. Your problem is the throttle pot or somtime called the engager. or the speed pot.
1.. Replace the throttle pot and or (speed pot most likely the problem).
Good Luck
Tim
Apr 30, 2011 | Drive Medical Drive Phoenix 4 wheel...
Set to move at 8 mph on full charge speed set to max only moving at 1 mph or less using battery charge in 20 mins
Jan 17, 2011 | Pride New Mobility Victory XL 4 Wheel...
Batteries are fully charged. Scooter goes at full speed for approx. 1 block, then will slow to 1/2 speed and back up to full then back to 1/2. We have new batteries, checked for voltage at end of run, one...
Jan 05, 2011 | Pride Mobility Products Celebrity X - 3...
I have a 2002four wheel Legend Mobility scooter.
Hi. A lot of scooters have a seperate switch to select a high or low speed setting.
This switch is sometimes labeled indoor/ outdoor.
I have had a few scooters with a similar fault, and the wires that connect to the high/low switch have broken of the terminals on the rear of the switch.
It could also be a faulty speed control pot.
Check these and good luck. Neil.
Mar 08, 2010 | Pride Mobility Products Legend 4-Wheel...
I have a Pride Legnd..the scooter started loseing speed, I would adj the speed pot and the unit would stop, adjust back down and unit would run, but slow. I left the speed speed controller alone and unit...
Regards
GeWiz.
Dec 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
Rally PRIDE 3-WHEEL SCOOTER
Sounds like you have a bad throttle pot. You`ll need to check the resistance on it or take it to a dealer.
Dec 29, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Health & Beauty Logo
88 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
