Question about Pioneer PDP-507CMX Television
My Pioneer PDP-507CMX won't turn on. Standby light is on but cannot turn on by remote or power button.
Posted by tanq801 on
Anonymous
Wot is buttons&ir lock
Posted on Sep 05, 2009
1 Related Answer
Mvp4eva
  • 24 Answers
SOURCE: My Pioneer PDP-507CMX won't turn
Hi there, first, there's a common problem with flat panels, and that is overheating issues.
Most flat panels in general suffer from powering up due to failure of capacitors that are located on the internal power supply board, reason for this is extensive heating .
If you don't mind to disassemble your TV, look at the power supply first; look for burnt parts and specially for bad capacitors.
A sign of a bad capacitor is to look at the top of the capacitor, if the top is flat is good, if the top is bulged up is bad.
Example:
Another example of a bad cap.
The top of the capacitor has to be totally flat to be good, if is even a slight bulge on the cap, is bad
If your willing to do this task and with a little soldering knowledge, you can go and get these parts at a computer parts store for a few bucks and you can save a ton this way.
Hope this help and thanks for choosing Fixya.
Posted on Sep 27, 2010
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
Pioneer pdp 507cmx has no sound does this tv have speakers
Yes,every tvs have a basic pair of speakers.Tries tv unplug,replug it back like about an hour later.Go into the tv Menu go to PICTUTRE SETTING go down to do a resetting for a back to factory setting of the whole tv main Tuner signal board.Go to Audio Setting go down to a resetting for the factory audio setting.Tries these steps,tv now should have sound back.
May 10, 2011 | Pioneer PDP-507CMX Television
Example:
Sep 27, 2010 | Pioneer PDP-507CMX Television
Anyway to turn on pioneer pdp 4350 with no remote?
If I'm thinking correctly, there are buttons right side of the TV. Besides the power buttons on the front of the TV and the box, there is a Standby/ON button. Somewhat hidden, but it's there. The top button on the right should turn the whole thing ON.
Mar 02, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
My brandnew Pioneer PDP-5020FD won't turn on.
Check page 9 of this document:
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/PDP-5020FD_OperatingInstructions0610.pdf
You will see that there is a power button on the bottom right corner of the back of the unit (item 25). Turn the unit on using that first.
Mar 17, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Pioneer PDP-6072HD will not turn on
You have a shorted circuit board inside the TV.
Jul 11, 2017 | Pioneer PRO-FHD1 50 in. Plasma Television
Pioneer PDP-507CMX Television Logo
507 people viewed this question
Top Pioneer Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
