HP LASERJET P1006 Printer Logo
t
thanmitha sadhanala Posted on May 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paper jam and we cant see the paper - HP LASERJET P1006 Printer
Khizar Hayat
Level 2:
New Friend:
  • Expert 72 Answers
  • Posted on May 26, 2015
Khizar Hayat
Expert
Level 2:
New Friend:
Answers
72
Questions
0
Helped
43989
Points
140
Open toner door pull out the toner ,now remove the paper.
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Have a paper jam in my pixma ip4500 and cant see the paper anywher to take it out?
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
>Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Paper jam on display but there's no paper jam
Then the roller are dirty or need to be replaced because they cant grab the paper so the machine is miss feeding jam is when the paper hit something or stop electrically move to different draw or the by pass
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
Machine says paper jam but cant find any paper stuck?
While working with your Samsung printer you may encounter a paper jam. Paper jams are usually obvious, but sometimes you may face a situation when there is no indication that the paper has jammed up the printer, in that case, open it up and visually inspect it to search for the jammed paper.
We have a paper jam according to the display but have found small pieces of paper tucked away but cant find any more is there a reset or is there somewhere more may be that we cant see/get to?
If your machine is detecting a jam with no obvious signs of paper, you most likely have small amounts of debris or dirt blocking the jam sensor. I suggest manually feeding a piece of thick card stock through the paper path, then spray the path with some canned air, as this will act to clear any dirt blocking the jam sensor.
-David.
Cant see paper jam but when I try to copy I get paper jam message
The paper sensor flag is most probably jammed. This will require you to take it to yor closest repair centre. Ths uually happens when you had a paper jem and pilled the paper out in the wrong direction.
False paper jam
check front and rear paper sensors. Maybe they damaged. Clean optical sensors.
HP 2360 Paper Jam
pls look the swich for paper inside, maybe the switch did not tuns back to his position
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
k24674
Grand Canyon Tech
Grand Canyon Tech
