Sony SGPT111US/S S1 TABLET 16GB 9.4IN WIFI ANDROID Logo
I AM UNABLE TO UNLOCK THE LOGON SCREEN AS MY CHILD SET IT AND FORGOT THE PASSWORD.
How do I recover from a forgotten password?
If you have forgotten your 4-digit pin, the only solution is to do a factory reset. Here are the instructions on how to perform a factory reset: nabi Show the world what you can do
2answers
How do I unlock my tablet
If it's android then you can reset it but you will lose all the apps you installed along with any saved passwords.
power off the tablet by holding down power until screen goes blank.
hold both the power button and the volume up button for at least ten seconds.it should boot to android logo...then a robot with red exclamation.leave it alone until the option to reset screen appears.
follow onscreen instructions to reset.
3answers
How to unlock tablet that has a forgotten pattern on it
if you have a google account, you can do this option
  1. When you try different patterns and unable to unlock your phone in five attempts. Then a message pop-up and shows two buttons "next" and "try again".
  2. Now click on "next" button and you see two options for unlocking phone. One is answer the security question and the second option is to provide Google account details.
  3. Mostly people don't set a security question. But if you set it then simply answer the question and unlock your device quickly. Otherwise check the Google account option and click "next".
  4. Now provide your Google account username and password attached with your device and click on "sign in".
  5. After that you are directed to choose new pattern and now you can unlock with this pattern.
if you don't have your google account, you can do the recovery option, but you will lose all your data in there
  1. Power off your phone.
  2. Now press Volume up, power and home button at the same time and wait until your device starts.
  3. When you see logo screen release the power button and keep pressed the other two buttons.
  4. Now your screen shows android system recovery and there is a list. Use Volume up or down keys to select option from the list. And select factory reset option and then press power button to let the action begin.
  5. Now it asks you for confirmation, select "yes".
  6. After factory reset completes, it again shows you android system recovery screen. Now select reboot option and after restart it will not ask you for pattern.
3answers
Forgot home screen password for Samsung 12.2 tablet. How do I unlock it?
If it's an android device...
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
O.k. I can not unlock my nextbook premium 7 and it dose not have a volume buttono
Well, you could try the following first: 1. go to the Lock screen of your tablet. 2.Now give the wrong password for more than 5 times in 30 seconds. 3.Now you will be taken to the screen in which you will find the option of 'Forgot Password' and then go for it. 4.Now you will be shown with the option to provide your Gmail Account details. 5.Give the required details and then you will be taken to screen to set the new password for your tablet. 6.After setting the password you can unlock your tablet using that password. supplied by cohort sai charan **************************
If after trying and it does not work then http://www.nextbookusa.com/techsupport.php
Password unlocker
go online to your account, settings, first choice is forgot password. The next screen will ask for your email. They will probably send you and email with instructions.
My Child Pad won't come on. My dad thinks it's something to do with the screen but I'm not so sure. Why won't it come on and how can I fix it?
I think I may be able to help you. So the same prob;e came with my childpad. Just remember as long as it does not work have the password with you. Because my works now but I forgot the password. So I opened the back blue thing. And then I figured that the charging thing was to loose. So, I just have to make it so that the charger won't come out, so some how my dad make it tighter. But I think that might be the problem with yours as well. If you have a solution to my problem (forgot password) please email me at [email protected] Thanks!! And I hope it helped in some way :)
3answers
Forgot password on the acer netbook with windows7
Have you forgot windows 7 password?
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset as your reference.
As an easy method to reset Windows 7 password , there are only four steps as follow:
Step1: Download Windows Password Reset Deluxe and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
Forgot windows logon password need backdoor passwords for 2805-S301 toshiba labtop
Get on Google and search for Hiren's boot disk. download ISO and burn to cd, boot cd and look through menus for Lockpick. It will allow you to reset the windows password, NOT the bios or SYS pw set in the bios.
Top Sony Tablets & eReaders Experts
Stan Ford
ADMIN Andrew
ADMIN Andrew
winchester
winchester
Are you a Sony Tablet and eReader Expert? Answer questions, earn points and help others
