Question about Toshiba Satellite A75-S2112 Notebook
Lt truns off
Hello, i have a toshiba laptop (satellite a 75-s2112) every time i try to brun a cd it starts and then like 1 min in...the whole things turns off... I have a external fan, and it still did not help, all the power settings are to max...what might it be
Posted by pgyouth on
  • pgyouth Nov 14, 2007
    *************sorry I said CD but I ment DVD***********
  • Nailb19 Jan 08, 2008
    I have the same problem, not only when I burn CD's but when the laptop is on, it's on for a certain amount of time, and then just turns off.
Anonymous
You don't really have to disasemble the computer. Just use a compressed air to blow it out. you can buy compressed air in a can, or use an air gun if you have one. I just use an air adapter on my scuba tank, and in less than a minute I am back in business.
Scott
Posted on Jan 23, 2008
natatit
The a75-s2112 is a great powerhorse when it works. The problem you are having is due to the fact that the processor used is from a desktop computer. So it gives off alot more heat then a normal laptop but has a blazing fast speed. Since it has a higher heat it needs more air to keep it cool, so toshiba put 2 large fans on the bottom. Great thinking right?? So the problem begins with the fans and their placement. Over a period of time the fans suck up so much dirt an lint it begins to clog worse then you lint vent on a dryer. So there fore it needs to be cleaned a few times a year. I usually do mine once every 2 months or so.You can google "dissembling a75-s2112"and find a guide complete with pictures. Toshiba makes it so easy compared to other manufactures. So i cant complain. I use two a75's alot for mobile music recording an production with great results. Good luck
Posted on Jan 18, 2008
Thomas Christopher
    Genius:
  • 1,601 Answers
Is this the first time you have burned a DVD on this laptop?
Posted on Nov 14, 2007
Recovery xp
Need more information; Recovery CD will whipe out all data and reinstall everything.
If this is what you need to do, you need to contact Toshiba and ask them to send you a new Recovery CD explaining to them the old CD is damaged and unreadable.
They more than likely will charge you for the new recovery CD.
Sep 25, 2013 | Toshiba Satellite A75-S2112 Notebook
I need recovery xp cdToshiba Satellite A75-S2112 Notebook
Call Toshiba and order a new CD.
They will charge you for it.
Dvd/cd not recognized by the computer
Assuming that it was working and now has stopped, you can try to run the utility called CDGone.
To find it, Google CDGone.
If this doesn't work, then most likely the drive has gone bad and must be replaced.
var fctb_tool=null; function FCTB_Init_d27594de151445438570d3de7b24bce4(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_b49e7f31f5434b8e8b4a151c25aecfdf(t) { fctb_tool=t; start(fctb_tool); }
Dec 29, 2010 | Toshiba Satellite A75-S2112 Notebook
Toshiba Satellite bypasses bios and boots straight into windows please help. Pressing F2 or trying to boot into safemode does not help.
sometimes thewindow of time you have to hit the f2 key is very short. if you can't open the bios by tapping on the f2 button before it says "starting windows", try removing one the the memory sticks and restart with just one installed . The computer should see the change and prompt you into the bios.
Regards
Apr 02, 2010 | Toshiba Satellite A75-S2112 Notebook
I have a Toshiba Satellite A75-S2112. It is
there is a panel underneath with a small phillips head screw holding it. take battery out first, then flip computer over. Take out screw(place in zip loc bag for later)..ground your hands on metal somewhere, and then release the memory cards, by holding extreme outside edges. make sure NOT to touch gold fingers. Make certain you have compatible memory before you do this.
Nov 29, 2009 | Toshiba Satellite A75-S2112 Notebook
My Toshiba laptop is 4.5 years old, it shuts off after 10 minutes, why?
first try to format the c drive and reinstall the OS if its not working .........
its may be the problem with the smps of the laptop ................
Oct 07, 2009 | Toshiba Satellite A75-S2112: A75-S2112...
You can get a replacement screen here. http://base.google.com/base/a/309518/D787066591146521512
 Installation can be tricky.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Dec 14, 2008 | Toshiba Satellite A75-S2112 Notebook
Toshiba Satellite M45-S351 PC Notebook
cutemah, Is your cd/dvd internal or usb? Have you tried to login using safemode? When the first Toshiba screen appears press the F8 key. Choose safe mode. Since you say the cd/dvd isn't being recognized that too may be the problem. Try removing the cd/dvd player and see if the machine starts. Is the error code only 0x57 or is there more? It is sounding more hardware related than software related. What program are you using to format the hard drive? Send me a little more information please. Let me know what happens. Good Luck, Tim
Mar 14, 2007 | Toshiba Satellite M45-S351 Notebook
Toshiba Satellite A75-S2112 Notebook Logo
135 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
