The line fuse is okay, the three door interlock switches are okay, there is 12 volts to the connector on the back of the control panel circuit board...but the display is blank and there's no response to any membrane switch. There is no tech sheet inside the oven and I can't find any schematic online.
SOURCE: JVM1320WB001 1000W
The problem is damage to the control circuit board. This damage is usually caused by removing or installing light bulbs without disconnecting the oven from the power line first. We regularly repair these GE / Samsung smart boards for this problem for customers from across the country for $32.50. We have an important file called "safety.txt" which you can find by doing a search for "microwave safety.txt" on Yahoo.com. It's important information to consider before proceeding. When the varistor fails, it will be shorted. That will cause the whole oven to be "dead". It's almost certainly fine.
SOURCE: KitchenAid Superba combination built-in oven
It sounds like a stuck relay or other controller problem.
I don't have the service data on this one, but there should be a schematic or tech sheet / mini-manual either on the back side, behind the controls, or somewhere else inside.
If you or someone you know can locate them and scan and e-mail or copy & fax them to me, I can probably give you further guidance.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Panasonic nn-p295 blows buss fuse when turned on for cooking
If it went dead almost
immediately after pressing the Start pad, that's usually a shorted
high-voltage capacitor.
If it went dead a few
seconds after pressing the Start pad, that's usually a failing
high-voltage transformer. But this is likely an inverter model, so it wouldn't have one and would be some other component in the inverter I'd say.
If
it goes dead or blows the breaker (or GFI) when you plug it in or open
or close
the door, then there's a problem with a door switch or door switch
mount.
know
decide to look into it, we have critical safety information and
disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you
or someone you know can use (in order given) for test help, but read
the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
The best place to order
Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: Dacor DMT2420S Blank display, oven does not work
It sounds like you need to have the control panel assembly repaired or your CPU unit replaced and you need a new bottom door switch.
We
regularly repair these control units for customers nationwide by
mail for $39.95 postpaid in about a week or so with a one-year
guarantee.
Or you can order our exclusive modified control unit with our
proprietary upgrades
for $115, then if you return your defective control unit in repairable,
good cosmetic condition, we'll give you a core refund of $30. It comes
with a one-year guarantee. See details here.
We have the service manual and have uploaded it our site here to help you. It covers disassembly.
Also see this file.
You can order a universal type switch here for $5 postpaid.
Feel free to contact me directly for more help and information.
We're
happy to help you with free advice and we'd appreciate your thoughtful
William E. Miller
[email protected]
SOURCE: no display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
